Quick find
Product features:
Xtreme N Gigabit Router
EOL
General features:
STANDARDS
+ IEEE 802.11n (draft)
+ IEEE 802.11g
+ IEEE 802.11b
+ IEEE 802.3
+ IEEE 802.3u
+ IEEE 802.3ab
DEVICE INTERFACES
+ 802.11n (draft) Wireless LAN
+ 10/100/1000BASE-T Gigabit WAN port
+ 4 10/100/1000BASE-T Gigabit LAN ports
+ USB 2.0 port
ANTENNA TYPE
3 external 2dBi RP-SMA dipole antennas
SECURITY
+ 64/128-bit WEP
+ WPA & WPA2 (Wi-Fi Protected Access)
ADVANCED FIREWALL FEATURES
+ Network Address Translation (NAT)
+ Stateful Packet Inspection (SPI)
+ VPN Pass-Through/Multi-Sessions PPTP/L2TP/IPSec
QoS
+ QoS Engine for prioritizing traffc
+ WISH Stream Engine
DEVICE MANAGEMENT
+ UPnP support
+ DDNS support
+ Integrated Wireless Security Wizard
+ Windows Connect Now (WCN) support
+  Web-Based management using Internet Explorer v6 or later; Mozilla Firefox v2.0 or later; or other Java-Enabled browsers
+ Automatic frmware update notifcation
+ E-Mail notifcation for triggered events
SharePortTM FUNCTION SUPPORT
   -   Allows connection of external hard drive or multifunction printer to USB port
   -   Allows sharing of HD space, printing and scanning functions*
INSTALLATION
+ Quick Router Setup Utility
+ SharePortTM Network USB  Utility
+ Desktop or wall mount
MINIMUM SYSTEM REQUIREMENTS
+ Computer with:
   - Pentium 3 800GHz or better processor
   - 256MB RAM or higher
   -  Windows Vista, XP SP2, 2000, 2003 or
Mac OS X v10.4 or higher
   - CD ROM drive
   - SharePortTM Network USB Utility
RECOMMENDED SYSTEM REQUIREMENTS
For optimal wireless performance:
+   Rangebooster NTM 650 adapters (DWA-645)
LEDS
+ Power
+ Status
+ Internet / WAN
+ WLAN
+ LAN
+ USB
DIMENSIONS
120.5 x 198 x 32 mm (4.6 x 7.6 x 1.3 inches)
WEIGHT
341.5 grams (0.75 lb)
CERTIFICATIONS
+ FCC Class B
+ CE
+ IC
+ C-Tick
+ Wi-Fi b/g/n
+ WMM
+ Works with Windows Vista
Products | Support  | News  | About |
