DI-524EOL EOS
802.11g Wireless Broadband Router
Where to buy
Description
High-Speed Wireless Speed
The DI-524 router offers a maximum wireless signal rate of up to 54Mbps through its wireless channels, allowing streaming videos and other high bandwidth applications such as on-line gaming and video clips to operate without the hassle of Ethernet cables. The ability to handle high bandwidth applications also makes streaming real time programs more enjoyable and more efficient.
Advanced Built-in Firewall
The DI-524's built-in firewall makes it more difficult for hackers to penetrate your network. Firewall features include functions to allow or disallow certain ports to be open for certain applications. Time scheduling can be applied to the firewall rules to have specific ports open at certain times and to be closed at other times. Features like content filtering, MAC filtering, URL blocking, and domain blocking are useful tools to prevent unwanted intruders from connecting to your network or browsing restricted sites.
Easy Setup and Secure Data Transfer
A simple, intelligent web-based setup wizard is provided with the DI-524 to allows users to quickly set up the router and connect computers to share a high-speed Internet connection, files, resources, games or just to communicate.
Integrated Ethernet Switch
Multiple wireless clients can also securely connect to the network using 64-bit or 128-bit WEP data encryption.An integrated 4-port switch allows ready connection of up to 4 computers. This saves you the cost of purchasing and installing a separate switch for network computer connections.
General features
Standards
- IEEE 802.11g
- IEEE 802.11b
- IEEE 802.3
- IEEE 802.3u
Wireless Modulation Technology
Orthogonal Frequency Division Multiplexing (OFDM)
Wireless Frequency Range
2.4GHz to 2.462GHz
Wireless Signal Rates
(With automatic fallback)
54Mbps, 48Mbps, 36Mbps, 24Mbps, 18Mbps, 12Mbps, 11Mbps, 9Mbps, 6Mbps, 5, 5Mbps, 2Mbps, 1Mbps
Wireless Receiver Sensitivity
- 54Mbps OFDM, 10% PER, -68dBm
- 48Mbps OFDM, 10% PER, -68dBm
- 36Mbps OFDM, 10% PER, -75dBm
- 24Mbps OFDM, 10% PER, -79dBm
- 18Mbps OFDM, 10% PER, -82dBm
- 12Mbps OFDM, 10% PER, -84dBm
- 11Mbps CCK, 8% PER, -82dBm
- 9Mbps OFDM, 10% PER, -87dBm
- 6Mbps OFDM, 10% PER, -88dBm
- 5.5Mbps CCK, 8% PER, -85dBm
- 2Mbps QPSK, 8% PER, -86dBm
- 1Mbps BPSK, 8% PER, -89dBm
Wireless Transmit Output Power
15dBm +/- 2dBm
External Antenna Type
Single detachable reverse SMA
Wireless Operating Range
- Indoors: up to 100 m
- Outdoors: up to 300 m
* Environmental factors may adversely affect operating range
Security
- 802.1x user authentication support
- 64-, 128-WEP wireless data encryption
- WPA Wi-Fi Protected Access (WEP  with TKIP, MIC,
  IV Expansion, Shared Key Authentication)
Firewall Features
- NAT (Network Address Translation) with VPN pass-through
- MAC address filtering
- IP address filtering
- URL filtering
- Domain blocking
- Scheduling
VPN Pass-Through/Multi-Sessions
- PPTP
- L2TP
- IPSec
Device Management
- Web-based Internet Explorer v .6 or Netscape Navigator v6 or other Java-enabled browsers
- DHCP Server and Client
Diagnostic LEDs
- Power
- Status
- WAN
- LAN (10/100Mbps)
- WLAN
Power Input
Through external power adapter
Dimensions
273 (L) x 205 (W) x 66 (H) mm
Weight
1.32 kg
Operating Temperature
0  to 40 C
Humidity
90% maximum (non-condensing)
Safety and Emissions
- FCC
- CE
- C-Tick
Certificates
Order info
DI-524    802.11g Wireless Router With Built-in 4-Port Switch
Pictures
DI-524
Front view
Downloads
Support Resources
