DI-724P+EOL
Wireless Cable/DSL Router
Where to buy
Description
Simplified, Cost-saving Broadband Internet Connection
The DI-724P+ provides users with easy and cost-saving access to the broadband Internet through a DSL or cable modem without the need for wiring. To let everybody logon, this device automatically creates and assigns an IP number for each user, simplifying every one's logon operation.
High Wireless Speeds
At up to 54Mbps, this router provides wireless LAN users a very high data transfer rate. In addition, adoption of the 2.4GHz frequency, now available for public use in most countries, makes this router an ideal solution for bandwidth intensive WLAN applications.
Integrated Fast Ethernet Switch & Print Server
An integrated 4-port switch with auto MDI/MDIX support provides plug-and-play connection to 4 computers. In addition, a parallel print server port allows you to share a parallel printer among your users.
Built-in Firewall & Access Security
To prevent unwanted Internet intruders from accessing your private network, this router provides a feature-rich firewall and access security. Filters can be set based on MAC address, IP address, URL and/or domain name. Additional advanced features include pass-through of multiple concurrent IPSec and PPTP VPN sessions for telecommuters or for anyone who needs to transmit sensitive information securely.
Easy Setup
A simple yet intelligent, web-based setup wizard allows you to quickly set up the router for secure computer connection to share high-speed Internet connection, files, resources, games, or just to communicate.
General features
Software
WAN Port
- 10/100BASE-TX
- Supports "Always-on" (bridged) and PPPoE for DSL dial-up
LAN Ports
4 10/100BASE-TX ports with auto MDI/MDIX
Printer Port
DB-25 parallel port
LED indicators
- Power
- Status
- WAN
- WLAN
- Local (Ethernet) Network (4 LEDs)
NAT
- IP Network Address Translation
- Traditional IP Network Translation
- Protocol Complications with IP Network Address T ranslation
- DHCP server and client support
- Subnet mask class A, B, and C
- DHCP server class C (1 to 254 clients)
NAT Application Level Gateway
- H.323 Protocol Suite
- File Transfer Protocol (FTP)
- Session Initiation Protocol (SIP)
- Session Description Protocol (SDP)
- Real-Time Transport Protocol (RTP)
- Internet Relay Chat (IRC)
- Multiple Gaming Protocol
Virtual DMZ Host
1 entry
Virtual Server Mapping
13 entries
VPN Support (Multi-Session)
- PPTP pass-through
- L2TP pass-through
- IPSec pass-through
Routing (Protocols & Functions)
- Static Route
- Dynamic Route
- RIP-1, RIP-2
- IP Alias
- IP Multicast
- UDP, TCP, ICMP , ARP
- IP spoofing
Firewall Functions
- Stateful Packet Inspection (SPI)
- Packet Filtering
- Ping of Death prevention
- IP spoofing
- Intrusion Detection
- Security event log
Firewall (Stateful Packet Inspection)
- IP Address and Port Number
- Packet Count and Byte Count
- Sequence and Acknowledgement Number
- Timestamps
- Payload Modification History
- Dynamic Association
Firewall (Comprehensive Logging)
- Filtering activity: logs rejected internal and external connection requests
- Session tracking activity: logs all session creation and termination information
- Intrusion detection activity: log information about outside attack
Access Control
- User access control: MAC filtering, Access Control List (ACL), 802.1x authentication, WPA (WLAN)
- WAN access control: domain filtering, URL filtering, WAN connection scheduling
Print Server OS Support
- Windows 95, 98, ME, 2000, XP , NT
- MacOS
- Linux
Configuration and Management
- Web-based Utilities
- PC Utility supporting Windows 98SE, ME, 2000, XP
- UPnP support
- Network Time Protocol (NTP) support
- Status log
Software Upgrade
Web-based
Built-in Wireless LAN
Wireless LAN Standards
- 802.11b
- 802.11b+
- 802.11g
Data Rates
- 802.11g: up to 54Mbps (6/9/12/18/24/36/48/54Mbps)
- 802.11b+: up to 22Mbps
- 802.11b: up to 11Mbps (1/2/5.5/11Mbps)
- Auto-switch to select 802.11g or 802.1 1b mode
- Data rate auto fall-back under noisy environment or longer range distance
Transmission Technology
DSSS
RF Frequency Range
2.4 to 2.4835GHz
Frequency Stability
Within +/- 25ppm
Operating Channels
- 1 to 11 channels (North America)
- 1 to 13 channels (General Europe)
Data Modulation Type
DBPSK, DQPSK, CCK, PBCC and OFDM (BPSK/QPSK/16-QAM/ 64-QAM)
Antennas
- 1 detachable external dipole antenna, 2dBi Gain (reverse SMA connector)
- 1 internal antenna, 2dBi Gain
Transmit Output Power
- 802.11g: 14dBm (typical)
- 802.11b: 16dBm (typical)
Receive Sensitivity (for 802.11b)
(typically @PER < 8% packet size 1024 @ 25  C +/- 5  C)
- 22Mbps (PBCC): -80dBm
- 11Mbps (PBCC): -85dBm
- 11Mbps (CCK): -84 dBm
- 5.5Mbps (CCK): -87 dBm
- 2Mbps (QPSK): -90 dBm
- 1Mbps (BPSK): -92 dBm
Receive Sensitivity (for 802.11g)
- 54Mbps (OFDM): -71 dBm
- 48Mbps (OFDM): -72 dBm
- 36Mbps (OFDM): -77 dBm
- 24Mbps (OFDM): -80 dBm
- 12Mbps (OFDM): -86 dBm
- 9Mbps (OFDM): -87 dBm
- 6Mbps (OFDM): -89 dBm
Operating Range *
- Indoors: 100 meters (328 feet)
- Outdoors: 400 meters (1,312 feet)
* Environmental factors may adversely affect range
Wireless Data Security
- WEP 64/128/256-bit data encryption (user-selectable)
- 802.1x user authentication (MD5 and TLS) (in Windows XP only)
- Wi-Fi Protected Access
- SSID broadcast enable/disable
Built-in Fast Ethernet Switch
Standards
- IEEE 802.3 10BASE-T Ethernet
- IEEE 802.3u 100BASE-TX Fast Ethernet
- ANSI/IEEE 802.3 NWay auto-negotiation
Supported Functions
- Full/half duplex (per port)
- MDI/MDIX auto uplink (per port)
Transmission Method
Store-and-forward
MAC Address Learning
Automatic update
DC input
- 5V/2A
- Through external power adapter
Dimensions
192 x 118 x 31 mm (device only)
Weight
300 grams (device only)
Operation Temperature
0   to 55  C
Storage Temperature
-20 to 70  C
Humidity
5% to 95% non-condensing
Emission (EMI) Certifications
- FCC Part 15 Class B, Sec. 15.247, 15.109
- ETS 300 328, ETS 301 489-1&17, CE mark
Wireless LAN Compatibility
Wi-Fi Compliant
Box Includes
- DI-724P router
- External power adapter
- Ethernet Cable
- Quick Installation Guide
- Manual on CD
- 4 rubber feet
- 1 set of screws
Certificates
Order info
DI-724P+   Wireless Router With Built-in 4-Port Switch and Parallel Printer Server
Pictures
DI-724P+
Front view
Downloads
Support Resources
