DSR-1000ACEOL EOS
Description
The D-Link DSR Series Unified Services Routers provide secure, high-performance networking solutions to address the growing needs of small and medium businesses. With integrated high-speed wireless technology, the DSR series routers offer comparable performance to wired networks, but with fewer limitations. Next generation wireless performance is available on the DSR-500AC and DSR-1000AC, which introduces 802.11ac support to the family. Available on the 5 GHz band, the combination of wider Radio Frequency bandwidths take data rates available to clients supporting the wireless AC standard to the next level.
Comprehensive Management Capabilities
The DSR-500/500AC and DSR-1000/1000AC Unified Services Routers include dual WAN Gigabit Ethernet ports to provide high availability for your WAN or Internet connections. Traffic can be load-balanced across the links with Outbound Load Balancing, increasing the performance and availability of business applications. The secondary WAN port can also be used to create a DMZ, isolating servers from your LAN. The DSR series supports mobile broadband networks via an extendable USB modem*, such as 3G or 4G** dongles. Traffic load balancing can be performed on the mobile data connections, providing an additional layer of redundancy for critical or backup applications.
Web Authentication Capabilities
Captive Portal allows employees and guest users to be easily authenticated and authorized by accessing a customized landing page. Users can be authenticated by a local database, RADIUS, LDAP, Microsoft Windows Active Directory, NT Domain and POP3 server. A maximum of four servers can be configured at any one time.
Complete and Robust VPN Features Web Content Filtering
A fully featured virtual private network (VPN) provides your mobile workers The DSR series also and branch offices with a secure link to your network. The DSR series routers administrators are capable of Generic web content filtering Routing Encapsulation (GRE) tunnels, empowering your mobile users by ActiveX, and cookies, or to providing remote access to a central corporate database. Site-to-site VPN filtering, which tunnels use IP Security (IPSec) Protocol, Point-to-Point Tunneling Protocol content from a list (PPTP), or Layer 2 Tunneling Protocol (L2TP) to facilitate branch office URLs and real-time connectivity through encrypted virtual links.
The DSR series also provides a web content filtering feature to help administrators monitor, manage and control employees™ Internet usage. Static web content filtering helps to remove malicious objects such as Java applets, ActiveX, and cookies, or to block URLs by keyword. Dynamic web content filtering, which requires a license subscription, allows administrators to filter content from a list of categories. Multiple global index servers, with millions of URLs and real-time website data, enhance performance and maximize service availability.
General features
Ethernet Interface
• 2 10/100/1000 Mbps WAN Ports
• 4 10/100/1000 Mbps LAN Port
Wireless Interface
• 802.11 ac/a/b/g/n (Concurrent dual band)
• 3 Detachable 2 dBi Omni-Directional Antennas
USB 2.0
• 2 USB 2.0 ports
Console port
• RJ-45
Performance***
Firewall Throughput****
• 950 Mbps
VPN Throughput*****
• 250 Mbps
Concurrent Sessions
• 100 000
New Sessions (per second)
• 1000
Firewall Policies
• 600
Internet Connection Type
• Static/Dynamic IP
• PPPoE/L2TP/PPTP
• Multiple PPPoE
Firewall System
• Static Route
• Dynamic Route: RIP v1/v2, OSPF, OSPFv3
• Dynamic DNS
• Inter-VLAN Route
• NAT, PAT
• Web Content Filtering: Static URL, Keywords, Dynamic WCF (License is required)
• Intrusion Prevention System (IPS): Signature Package Included in Firmware
• Authentication: Internal User Database, Radius, POP3, LDAP, AD, NT Domain
Networking
• DHCP Server/Client
• DHCP Relay
• IEEE 802.11q VLAN
• VLAN (port-based)
• IP Multicast: IGMP Proxy, IGMP Snooping
• IPv6
• Route Failover
• Outbound Load Balancing
• 3G/4G** Redundancy
Virtual Private Network (VPN)
• VPN Tunnels: 155
• IPSec Tunnels: 70
• PPTP/L2TP Tunnels: 25
• GRE Tunnels: 20
• Encryption Methods: DES, NULL
• IPSec/PPTP/L2TP Server
• IPSec NAT Trraversal
• Dead Peer Detection
• IP Encapsulating Security Payload (ESP)
• IP Authentication Header (AH)
• VPN Tunnel Keep Alive
• Hub and Spoke
Bandwidth Management
• Maximum Bandwidth Control
• Priority Bandwidth Control:
  - Port-based QoS
  - 3 Classes
System Management
• Web-based User Interface
• Command Line
• SNMP v1, v2c, v3
Wireless
Security
• Wired Equivalent Privacy (WEP)
• Wi-Fi Protected Setup (WPS)
• Wi-Fi Protected Access – Personal (WPA-PSK)
• Wi-Fi Protected Access – Enterprise (WPA-EAP)
• Wi-Fi Protected Access версия 2 – Personal (WPA-PSK)
• Wi-Fi Protected Access версия 2 – Enterprise (WPA-EAP)
• Multiple Service Set Identifier (SSID)
• Service Set Identifier (SSID) to VLAN Mapping
Wireless Frequency
• 802.11b/g/n: 24 GHz to 2.483 GHz
• 802.11a/n/ac: 5.18 GHz to 5.825 GHz
Wireless speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit/s
• IEEE 802.11n (2.4 GHz): 6.5 ~ 300 Mbit/s
• IEEE 802.11n (5 GHz): 6.5 ~ 150 Mbit/s
• IEEE 802.11ac: 7.2 ~ 1300 Mbit/s
Transmitter Output Power******
• IEEE 802.11a:
 15 dBm at 6~54 Mbit/s
• IEEE 802.11b:
 20 dBm at 1~11 Mbit/s
• IEEE 802.11g:
 14 dBm at 6~54 Mbit/s
• IEEE 802.11n:
 14 dBm at 6~300 Mbit/s (2.4 GHz)
 15 dBm at 6~150 Mbit/s (5 GHz)
• IEEE 802.11ac:
 12 dBm at 7.2~1300 Mbit/s
Receiver Sensitivity
• IEEE 802.11a:
 -82 dBm at 6 Mbit/s
 -81 dBm at 9 Mbit/s
 -79 dBm at 12 Mbit/s
 -77 dBm at 18 Mbit/s
 -74 dBm at 24 Mbit/s
 -70 dBm at 36 Mbit/s
 -66 dBm at 48 Mbit/s
 -65 dBm at 54 Mbit/s
• IEEE 802.11b:
 -89 dBm at 2 Mbit/s
 -83 dBm at 11 Mbit/s
• IEEE 802.11g:
 -82 dBm at 6 Mbit/s
 -81 dBm at 9 Mbit/s
• IEEE 802.11n:
 2.4 GHz/HT-20:
 -82 dBm at MCS0/8/16
 -79 dBm at MCS1/9/17
 -77 dBm at MCS2/10/18
 -74 dBm at MCS3/11/19
 -70 dBm at MCS4/12/20
 -66 dBm at MCS5/13/21
 -65 dBm at MCS6/14/22
 -64 dBm at MCS7/15/23
 2.4 GHz/HT-40:
 -79 dBm at MCS0/8/16
 -76 dBm at MCS1/9/17
 -74 dBm at MCS2/10/18
 -71 dBm at MCS3/11/19
 -67 dBm at MCS4/12/20
 -63 dBm at MCS5/13/21
 -62 dBm at MCS6/14/22
 -61 dBm at MCS7/15/23
 5 GHz/HT-20:
 -82 dBm at MCS0
 -79 dBm at MCS1
 -77 dBm at MCS2
 -74 dBm at MCS3
 -70 dBm at MCS4
 -66 dBm at MCS5
 -65 dBm at MCS6
 -64 dBm at MCS7
 5 GHz/HT-40:
 -79 dBm at MCS0
 -76 dBm at MCS1
 -74 dBm at MCS2
 -71 dBm at MCS3
 -67 dBm at MCS4
 -63 dBm at MCS5
 -62 dBm at MCS6
 -61 dBm at MCS7
• IEEE 802.11ac:
 VHT-20:
 -82 dBm at MCS0
 -79 dBm at MCS1
 -77 dBm at MCS2
 -74 dBm at MCS3
 -70 dBm at MCS4
 -66 dBm at MCS5
 -65 dBm at MCS6
 -64 dBm at MCS7
 -59 dBm at MCS8
 -57 dBm at MCS9
 VHT-40:
 -79 dBm at MCS0
 -76 dBm at MCS1
 -74 dBm at MCS2
 -71 dBm at MCS3
 -67 dBm at MCS4
 -63 dBm at MCS5
 -62 dBm at MCS6
 -61 dBm at MCS7
 -56 dBm at MCS8
 -54 dBm at MCS9
 VHT-80:
 -76 dBm at MCS0
 -73 dBm at MCS1
 -71 dBm at MCS2
 -68 dBm at MCS3
 -64 dBm at MCS4
 -60 dBm at MCS5
 -59 dBm at MCS6
 -58 dBm at MCS7
 -53 dBm at MCS8
 -51 dBm at MCS9
Physical Parameters
Power Supply
• External Power Supply Unit: DC 12 V/3 A
Max. Power Consumption
• 23.1 W
MTBF
• 360 000 hours
Dimensions
• 180 x 280 x 44 mm
Weight
• 1.728 kg with 3 antennas
Temperature
• Operating: 0 to 40В°C
• Storage: -20 to 70В°C
Humidity
• Operating: 5% to 95% non-condensing
Certifications
EMI
• FCC Class B
• CE Class B
• RCM
• IC
• VCCI
Safety
• cUL
• LVD (EN60950-1)
3rd Party Certification
• IPv6 Ready
• Wi-Fi
• VPNC Basic Interop
* The following portable modem are supported: DWM-152 A1/A2/A3, DWM-156 A1/A2/A3/A5/A6/A7, DWM-157 A1/B1, DWM-158 D1, DWP-156 A1/B1, DWP-157 A1/B1, Huawei E1550, E173, E303 and EC306.
** Available with future firmware upgrade.
*** Firewall throughput is measured using UDP traffic with a 1518 bytes packet size, adhering to RFC2544.
**** Actual performance may vary depending on network conditions and activated services.
***** VPN throughput is measured using UDP traffic with the packet size 1420 bytes and encryption method 3DES plus SHA-1, adhering to PFC2544.
****** Maximum power output varies in each country depending on local power regulations.
Certificates
Order info
DSR-1000AC Dual-Band Unified Wireless Service Router
