DIR-615EOL
Wireless N300 Router
Description
Wireless Interface
Using the DIR-615 device, you are able to quickly create a wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Smart adjustment of Wi-Fi clients is useful for networks based on several D-Link access points or routers – when the smart adjustment function is configured on each of them, a client always connects to the access point (router) with the highest signal level.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings and maximum rate limitation. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-615 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-615 via the user-friendly web-based interface (the interface is available in two languages – in Russian and in English).
The configuration wizard allows you to quickly switch DIR-615 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
Also DIR-615 supports configuration and management via mobile application for Android smartphones.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
General features
				 Hardware
				 Processor
				 • RTL8196E (400MHz)
				 RAM
				 • 32MB, SDRAM
				 Flash
				 • 4MB, SPI
				 Interfaces
				 • 10/100BASE-TX WAN port
				• 4 10/100BASE-TX LAN ports
				 LEDs
				 • POWER
				• WLAN / WPS
				• INTERNET
				 Buttons
				 • WPS/RESET button to set up wireless connection and restore factory default settings
				 Antenna
				 • Two non-detachable omnidirectional antennas (5dBi gain)
				 MIMO
				 • 2 x 2
				 Power connector
				 • Power input connector (DC)
				 Software
				 WAN connection types
				 • PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• Static IPv4 / Dynamic IPv4
				• Static IPv6 / Dynamic IPv6
				• PPPoE + Static IP (PPPoE Dual Access)
				• PPPoE + Dynamic IP (PPPoE Dual Access)
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				 Network functions
				 • DHCP server/relay
				• Stateful/Stateless mode for IPv6 address assignment, IPv6 prefix delegation
				• Automatic obtainment of LAN IP address (for access point/repeater/client modes)
				• DNS relay
				• Dynamic DNS
				• Static IP routing
				• Static IPv6 routing
				• IGMP Proxy
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• WAN reservation
				• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
				• Setup of maximum TX rate for each port of the router
				• Built-in UDPXY application
				 Firewall functions
				• IP filter
				• IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in Yandex.DNS web content filtering service
				 VPN
				 Management
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Web-based interface for configuration and management (Russian/English)
				• Support of mobile application for Android smartphones
				• Support of logging to remote host
				• Ping utility
				• Traceroute utility
				• TR-069 client
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11b/g/n
				 Frequency range
				 • 2400 ~ 2483.5MHz
				 Wireless connection security
				 • WEP
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Support of client mode
				• WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Smart adjustment of Wi-Fi clients
				• Guest Wi-Fi / support of MBSSID
				• Rate limitation for wireless network/separate MAC addresses
				• Periodic scan of channels, automatic switch to least loaded channel
				• Autonegotiation of channel bandwidth in accordance with environment conditions (20/40 Coexistence)
				 Wireless connection rate
				 • IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
				 Transmitter output power
				 • 802.11b (typical at room temperature 25 °C)
				15dBm (+/-1.5dB) at 1, 2, 5.5, 11Mbps
				• 802.11g (typical at room temperature 25 °C)
				15dBm (+/-1.5dB) at 6, 9, 12, 18, 24, 36, 48, 54Mbps
				• 802.11n (typical at room temperature 25 °C)
				HT20/HT40
				15dBm (+/-1.5dB) at MCS0/1/2/3/4/5/6/8/9/10/11/12/13/14
				14dBm (+/-1.5dB) at MCS7/15
				 Receiver sensitivity
				 • 802.11b (typical at PER = 8% at room temperature 25 °C)
				-95dBm at 1Mbps
				-93dBm at 2Mbps
				-90dBm at 5.5Mbps
				-87dBm at 11Mbps
				• 802.11g (typical at PER = 10% at room temperature 25 °C)
				-91dBm at 6Mbps
				-90dBm at 9Mbps
				-88dBm at 12Mbps
				-86dBm at 18Mbps
				-83dBm at 24Mbps
				-80dBm at 36Mbps
				-75dBm at 48Mbps
				-74dBm at 54Mbps
				• 802.11n (typical at PER = 10% at room temperature 25 °C)
				HT20
				-90dBm at MCS0/8
				-87dBm at MCS1/9
				-85dBm at MCS2/10
				-82dBm at MCS3/11
				-79dBm at MCS4/12
				-74dBm at MCS5/13
				-72dBm at MCS6/14
				-70dBm at MCS7/15
				HT40
				-87dBm at MCS0/8
				-84dBm at MCS1/9
				-81dBm at MCS2/10
				-78dBm at MCS3/11
				-75dBm at MCS4/12
				-70dBm at MCS5/13
				-69dBm at MCS6/14
				-67dBm at MCS7/15
				 Modulation schemes
				 • 802.11b: DQPSK, DBPSK, and CCK
				• 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
				• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 174 x 129 x 33 mm (6.8 x 5.1 x 1.3 in)
				 Weight
				 • 215 g (0.47 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 0.5A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 65 °C
				 Humidity
				 • Operating: from 10% to 90% (non-condensing)
				• Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 • Router DIR-615
				• Power adapter DC 12V/0.5A
				• Ethernet cable (CAT 5)1
				• Quick Installation Guide” (brochure)
1Only for DIR-615/T4D.
Certificates
Order info
DIR-615/T4D Wireless N300 Router
