DIR-850LEOL EOS
Wireless AC1200 Dual Band Gigabit Cloud Router
Where to buy
Description
The DIR-850L Wireless AC1200 Dual Band Gigabit Cloud Router lets you easily connect, control, and monitor a network using the future of wireless technology, today. It’s mydlink Cloud-enabled and supports the Shareport Mobile app to stream and share your media files.
Fast and Reliable Home Networking
The D-Link DIR-850L Wireless AC1200 Dual Band Gigabit Cloud Router creates a blazing fast home network that connects all of your computers and mobile devices to your broadband Internet connection. Concurrent dual-band 802.11ac brings you the future of high-bandwidth wireless connectivity allowing you to stream HD video, make Internet calls, and surf the Internet from every corner of your home without interruption. The DIR-850L’s Gigabit Ethernet ports provide high-speed wired connections for up to four PCs or other devices. It’s stylish, easy-to-use, and comes IPv6-ready for a reliable network today and tomorrow.
Use mydlink to Monitor Your Network
The Wireless AC1200 Dual Band Gigabit Cloud Router is mydlink Cloud-enabled, so you can effortlessly access and view your network no matter where you are. See who is connected to your router, change settings, or block someone from using your network connection, all from any Internet-connected PC, or any iOS or Android mobile device. Parents can monitor what sites their children are visiting, and can stay informed and in control on the go.
File Sharing Right at Your Fingertips
The SharePort Mobile app allows you to connect a USB storage device to the DIR-850L and instantly share documents, movies, pictures, and music with mobile devices. You can put your music library on a USB drive and share it with your entire home. You can show photos on the living room TV while a family member watches a movie on their mobile device. You can stream media files to multiple devices without interruption, or save them to your device for offline playback. The intuitive interface lets anyone immediately connect to a variety of entertainment options stored securely on your own storage device.
Smooth Streaming with Wireless AC
The DIR-850L uses the latest Wireless AC technology, which can provide transfer rates of up to 1.2 Gbps*. The router operates on both the 2.4 GHz and 5 GHz wireless bands at the same time using concurrent dual-band technology and four internal antennas. This allows you to browse the web, chat and email using the 2.4 GHz band, while simultaneously streaming digital media, playing online games, or making Internet phone calls on the 5 GHz band.
Easy to Set Up and Use
Get the DIR-850L up and running in no time right from your couch using the QRS (Quick Router Setup) Mobile app on your iOS or Android device. Simply plug in the router, open the app, and follow a few easy steps to get your home network connected without having to touch a computer. You can also instantly set up a secure network with just the touch of a button using Wi-Fi Protected Setup.
mydlink Zero Configuration
If you have additional mydlink cloud products, you can take advantage of mydlink Zero Configuration. Simply connect your mydlink-enabled device to the DIR-850L and the router will automatically link it to your mydlink account, allowing even novice users to set up and use their new device immediately. Set up a home survelliance network in an instant using D-Link Cloud Cameras, or effortlessly stream your media files across the Internet with our ShareCenter Cloud Storage products – no configuration required.
General features
Device Interfaces
• 802.11 a/b/g/n/ac wireless LAN
• Four 10/100/1000 Gigabit LAN ports
• 10/100/1000 Gigabit WAN port
• USB 2.0 port
Antenna Type
• 2x2 (2.4GHz) and 2x2 (5GHz) internal antennas
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3u
Wireless Speed
• 802.11a: 6, 9, 12, 18, 24, 36, 48 и 54 Mbit/s
• 802.11b: 1, 2, 5.5, 11 Mbit/s
• 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11n (2.4GHz/5GHz): 6.5 to 300 Mbit/s (MCS-0 to MCS-15)
• 802.11ac (5GHz):
MCS GI=800ns GI=400ns
20MHz 40MHz 80MHz 20MHz 40MHz 80MHz
0 13 27 58.5 14.4 30 65
1 26 54 117 28.9 60 130
2 39 81 175.5 43.3 90 195
3 52 108 234 57.8 120 260
4 78 162 351 86.7 180 390
5 104 216 468 115.6 240 520
6 117 243 526.5 130 270 585
7 130 270 585 144.4 300 650
8 156 324 702 173.3 360 780
9 x 360 780 x 400 866.7
The Output Power of Transmitter
• IEEE 802.11a:
18±2 dBm at 6, 9, 12, 18 Mbit/s
17±2 dBm at 24 Mbit/s
16±2 dBm at 36 Mbit/s
15±2 dBm at 48 Mbit/s
14±2 dBm at 54 Mbit/s
• IEEE 802.11b:
22 dBm at 1, 2, 5.5, 11 Mbit/s
• IEEE 802.11g:
19±2 dBm at 6, 9, 12, 18 Mbit/s
18±2 dBm at 24 Mbit/s
17±2 dBm at 36 Mbit/s
16±2 dBm at 48 Mbit/s
15±2 dBm at 54 Mbit/s
• IEEE 802.11n:
2.4GHz/HT-20
19 dBm at MCS0/1/2/3
18 dBm at MCS4
17 dBm at MCS5
16 dBm at MCS6
15 dBm at MCS7
2.4GHz/HT-40
18 dBm at MCS4
17 dBm at MCS5
16 dBm at MCS6
15 dBm at MCS7
5GHz/HT-20
18 dBm at MCS0/1/2/3
17 dBm at MCS4
16 dBm at MCS5
15 dBm at MCS6
14 dBm at MCS7
5GHz/HT-40
17 dBm at MCS4
16 dBm at MCS5
15 dBm at MCS6
14 dBm at MCS7
• IEEE 802.11ac (5GHz):
VHT-20
17 dBm at MCS4
16 dBm at MCS5
15 dBm at MCS6
14 dBm at MCS7
VHT-40
17 dBm at MCS4
16 dBm at MCS5
15 dBm at MCS6
14 dBm at MCS7
VHT-80
17 dBm at MCS0
17 dBm at MCS1
16 dBm at MCS2
16 dBm at MCS3
15 dBm at MCS4
15 dBm at MCS5
14 dBm at MCS6
14 dBm at MCS7
13 dBm at MCS8
12 dBm at MCS9
Receiver Sensitivity
• IEEE 802.11a:
–82 dBm at 6 Mbit/s
–81 dBm at 9 Mbit/s
–79 dBm at 12 Mbit/s
–77 dBm at 18 Mbit/s
–74 dBm at 24 Mbit/s
–70 dBm at 36 Mbit/s
–66 dBm at 48 Mbit/s
–65 dBm at 54 Mbit/s
• IEEE 802.11b:
–76 dBm at 1 Mbit/s
–76 dBm at 2 Mbit/s
–76 dBm at 5.5 Mbit/s
–76 dBm при 11 Mbit/s
• IEEE 802.11g:
–82 dBm at 6 Mbit/s
–81 dBm at 9 Mbit/s
• IEEE 802.11n:
2.4GHz/HT-20
-82dBm at MCS0/8
-79dBm at MCS1/9
-77dBm at MCS2/10
-74dBm at MCS3/11
-70dBm at MCS4/12
-66dBm at MCS5/13
-65dBm at MCS6/14
-64dBm at MCS7/15
2.4GHz/HT-40
-79dBm at MCS0/8
-76dBm at MCS1/9
-74dBm at MCS2/10
-71dBm at MCS3/11
-67dBm at MCS4/12
-63dBm at MCS5/13
-62dBm at MCS6/14
-61dBm at MCS7/15
5GHz/HT-20:
-82 dBm at MCS0/8
-79 dBm at MCS1/9
-77 dBm at MCS2/10
-74 dBm at MCS3/11
-70 dBm at MCS4/12
-66 dBm at MCS5/13
-65 dBm at MCS6/14
-64 dBm at MCS7/15
5GHz/HT-40
-79 dBm at MCS0/8
-76 dBm at MCS1/9
-74 dBm at MCS2/10
-71 dBm at MCS3/11
-67 dBm at MCS4/12
-63 dBm at MCS5/13
-62 dBm at MCS6/14
-61 dBm at MCS7/15
VHT-20
-82 dBm at MCS0
-79 dBm at MCS1
-77 dBm at MCS2
-74 dBm at MCS3
-70 dBm at MCS4
-66 dBm at MCS5
-65 dBm at MCS6
-64 dBm at MCS7
-59 dBm at MCS8
-57 dBm at MCS9
VHT-40
-79 dBm at MCS0
-76 dBm at MCS1
-74 dBm at MCS2
-71 dBm at MCS3
-67 dBm at MCS4
-63 dBm at MCS5
-62 dBm at MCS6
-61 dBm at MCS7
-56 dBm at MCS8
-54 dBm at MCS9
VHT-80
-76 dBm at MCS0
-73 dBm at MCS1
-71 dBm at MCS2
-68 dBm at MCS3
-64 dBm at MCS4
-60 dBm at MCS5
-59 dBm at MCS6
-58 dBm at MCS7
-53 dBm at MCS8
-51 dBm at MCS9
Minimum System Requirements
• Windows 7/Vista/XP SP3 or Mac OS X 10.4 or higher
• Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher, or other Java-enabled browser
• CD-ROM
• Ethernet network interface
• Cable or DSL modem
• Subscription with an Internet Service Provider
Advanced Features
• Guest Zone
• Web file access
• Multi-language Web Setup Wizard
• Green Ethernet
• DLNA Media server support
• Dual Active Firewall
• VPN passthrough/multi-session PPTP/L2TP/IPSec
mydlink Features
• Remote Management
• View current upload/download bandwidth
• View currently connected clients
• View web browsing history per client
• Block/unblock client network access
• Manage wireless network details
• Accessible through a web browser or iOS or Android mobile app
Mobile App Support
• mydlink Lite
• SharePort Mobile
• QRS Mobile
Wireless Security
• WPA & WPA2 (Wi-Fi Protected Access)
• Wi-Fi Protected Setup (WPS) PIN/PBC
Dimensions
• 93 x 116 x 145mm
Weight
• 330g
Power
• Input: 100 to 240V AC, 50/60Hz
• Output: 12V DC, 2A
Temperature
• Operating: 0 to 40°C
• Storage: -20 to 65°C
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• FCC Class B
• CE Class B
• C-Tick
• DLNA
• IPv6 Ready
• Wi-Fi Certified
• Wi-Fi Multimedia (WMM)
• Compatible with Windows 8
* Maximum wireless signal rate derived from IEEE standard 802.11ac (draft) specifications which are subject to change. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Certificates
Order info
Pictures
DIR-850L
Front view
Back view
Downloads
Support Resources
