Quick find
Product features:
Wireless N750 Dual Band Router
EOL
General features:
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11a
• IEEE 802.11b
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
WAN Connection Type
• Static IP
• Dynamic IP
• PPPoE
• PPTP
• L2TP
Device Interfaces
• Four 10/100/1000Base-T LAN ports
• 10/100/1000Base-T WAN port
• USB 2.0 port
Antenna Type
• Three external reverse SMA dual band antennas
Wireless Speed*
• 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11b: 1, 2, 5.5, 11 Mbit/s
• 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11n (2.4GHz): 6.5 to 300 Mbit/s
• 802.11n (5GHz): 6.5 to 450 Mbit/s
Transmitter Power
• 802.11a:
  19 dBm at 6-36 Mbit/s
  18 dBm at 48 Mbit/s
  16 dBm at 54 Mbit/s
• 802.11b:
  20 dBm at 1, 2, 5.5, 11 Mbit/s
• 802.11g:
  20 dBm at 6-36 Mbit/s
  19 dBm at 48 Mbit/s
  18 dBm at 54 Mbit/s
• 802.11n (2.4GHz):
  HT20
  20 dBm at MCS0-MCS4, MCS8-MCS12
  19 dBm at MCS5, MCS13
  18 dBm at MCS6, MCS14
  17 dBm at MCS7, MCS15
  HT40
  19 dBm at MCS0-MCS5, MCS12-MCS13
  16 dBm at MCS7, MCS15
• 802.11n (5GHz):
  HT20
  19 dBm at MCS0-MCS3, MCS8-MCS11, MCS16-MCS19
  18 dBm at MCS4-MCS6, MCS12-MCS14, MCS20-MCS21
  17 dBm at MCS22
  14 dBm at MCS23
  HT40
  18 dBm at MCS4-MCS5, MCS12-MCS13, MCS20-MCS21
  17 dBm at MCS6, MCS14
  16 dBm at MCS7, MCS15, MCS22
  13 dBm at MCS23
Receiver Sensitivity
• 802.11a:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbit/s
  -79 dBm at 12 Mbit/s
  -77 dBm at 18 Mbit/s
  -74 dBm at 24 Mbit/s
  -70 dBm at 36 Mbit/s
  -66 dBm at 48 Mbit/s
  -65 dBm at 54 Mbit/s
• 802.11b:
  -87 dBm at 1 Mbit/s
  -87 dBm at 2 Mbit/s
  -85 dBm at 5.5 Mbit/s
  -82 dBm at 11 Mbit/s
• 802.11g:
  -82 dBm at 6 Mbit/s
  -81 dBm at 9 Mbit/s
• 802.11n (2.4GHz):
  HT20
  -82 dBm at MCS0/8
  -79 dBm at MCS1/9
  -77 dBm at MCS2/10
  -74 dBm at MCS3/11
  -70 dBm at MCS4/12
  -66 dBm at MCS5/13
  -62 dBm at MCS6/14
  -64 dBm at MCS7/15
  HT40
  -79 dBm at MCS0/8
  -76 dBm at MCS1/9
  -74 dBm at MCS2/10
  -74 dBm at MCS3/11
  -67 dBm at MCS4/12
  -63 dBm at MCS5/13
  -65 dBm at MCS6/14
  -61 dBm at MCS7/15
• 802.11n (5GHz):
  HT20
  -82 dBm at MCS0/8/16
  -79 dBm at MCS1/9/17
  -77 dBm at MCS2/10/18
  -74 dBm at MCS3/11/19
  -70 dBm at MCS4/12/20
  -66 dBm at MCS5/13/21
  -65 dBm at MCS6/14/22
  -64 dBm at MCS7/15/23
  HT40
  -79 dBm at MCS0/8/16
  -76 dBm at MCS1/9/17
  -74 dBm at MCS2/10/18
  -67 dBm at MCS4/12/20
  -63 dBm at MCS5/13/21
  -62 dBm at MCS6/14/22
  -61 dBm at MCS7/15/23
Security
• WPA & WPA2 (Wi-Fi Protected Access)
• 64/128-bit WEP encryption
• Wi-Fi Protected Setup (WPS) - PIN/PBC
Device Management and Monitoring
• Microsoft Internet Explorer 6+, or Firefox 1.5+, or otherJava-enabled browsers
• D-link Network Monitor Yahoo! Widget
• D-link Internet Usage Meter Yahoo! Widget
• DLNA Server for streaming media to compatible media players*****
SharePort Plus Function Support
• Allows for connection of an external hard drive or multifunction printer to the USB port
• Allows sharing of hard drives, printing, and scanning functions****
QoS
• D-Link Intelligent QoS technology
Advanced Firewall Features
• IP/MAC address filtering
• VPN pass-through / Multi-session PPTP/L2TP/IPSec
• DMZ
Router Features
• Port Forwarding
• Port Triggering / Special applications support
• Static routes support
• WLAN Partition support
• DHCP server
• DNS Relay
Minimum System Requirements
• Windows®7/Vista**/XP SP3 или Mac OS®X(v10.4)***
• Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher
• CD-ROM
• Ethernet network interface
• Cable or DSL modem
• Subscription with an Internet Service Provider
Dimensions
• 198 x 120.5 x 32.5mm
Weight
• 370g
Power
• Input: 100 to 240V AC, 50/60Hz
• Output:  12V DC, 2A
Temperature
• Operating: 0 to 40°C
• Storage: -20 to 65°C
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• FCC Class B
• IC
• IPv6 Ready
• Wi-Fi Certified
• CE Class B
• C-Tick
• LVD
• RoHS compliant
• Windows 7
* Maximum wireless signal rate derived from IEEE Standard 802.11g, 802.11a, and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range. Wireless range and speed rates are D-link relative performance measurements based on the wireless range and speed rates of a standard Wireless G product from D-Link. Maximum throughput based on D-Link’s 802.11n devices.
** Computer must adhere to Microsoft’s recommended system requirements.
*** The software included with this product is not Mac-compatible.
**** Hard drives and multifunction equipment can only be accessed by a single user at a time.
***** D-Link does not guarantee full compatibility or proper playback with all codecs. Playback capability depends on the codec support
of the DLNA media player.
Products | Support  | News  | About |
