DIR-456/C1EOL EOS
High-speed Wireless 3G Router with Built-in GSM Modem and 4-port Switch
Where to buy
Description
The DIR-456 device is a high-speed wireless 3G router for UMTS/HSDPA networks with built-in GSM modem and 4-port switch. It provides a fast and simple way to create a wireless and wired network at home or in an office. In addition, DIR-456 can be used anywhere: the router is compact and equipped with a detachable rechargeable battery. Install a SIM card in the GSM modem of the router and you will be able to establish connection to the Internet. The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Using the DIR-456 device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS and WMM. Also the device is equipped with a port for connecting an analog phone using which you will be able to make and receive calls via the 3G network.
The high-speed wireless 3G router DIR-456 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN. You can configure and manage the settings of the 3G router DIR-456 via the user-friendly web-based interface (the interface is available in several languages).
General features
Interfaces:
• Built-in 3G modem
• 4 10/100BASE-TX Ethernet ports
• IEEE 802.11b/g/n
• USB 2.0 type A port
• RJ-11 port to connect an analog phone
Network Functions:
• 3G connection
• DHCP server and client
• DNS relay
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• RIP
3G Connection and SIM card:
• Auto connection to available type of supported network (3G/2G)
• Changing PIN code
Wireless Connection:
• WLAN splitting (up to 4 SSIDs)
• Supported security settings:
  • WEP
  • WPA/WPA2 Personal
  • WPA/WPA2 Enterprise
• MAC filter
• WPS
• Advanced settings
• WDS
• WMM
Firewall Functions:
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
Configuration and Management:
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote logging
• Automatic synchronization of system time with NTP server
LEDs:
• WLAN
• 4 LAN LEDs
• WPS
• 3G
• Power
Power:
• External power adapter
• On/Off power button
• Reset to Factory Defaults button
• WPS button
Battery:
• Voltage: 3.7V
• Capacity: 1500mAh
Operating Temperature:
from 0° to 45°C
Storage Temperature:
from -20° to 65°С
Operating Humidity:
from 10% to 90% non-condensing
Storage Humidity:
from 5% to 95% non-condensing
Certificates
Order info
DIR-456/C1  High-speed Wireless 3G Router with Built-in GSM Modem and 4-port Switch
Pictures
DIR-456/C1
Front view
Back view
Back view
Downloads
Support Resources
