DIR-645EOL EOS
Whole Home Router 1000
Where to buy
Description
Fast, reliable connections to your devices
The D-link Whole Home Router 1000 allows you to create reliable, high-speed connections to your wired and wireless devices. It features 802.11n wireless with D-link’s unique Smart Beam technology to provide wireless access to the Internet for your entire home or office. It also includes four gigabit LAN ports with easy to use port-based Quality of Service (QoS); simply plug in your wired devices in order of importance, and the Whole Home Router 1000 will automatically configure QoS for you. This allows you to watch smooth streaming video on your media PC or game console while surfing the web or downloading files on a PC. You can even connect a USB printer or storage drive and share it through D-link’s SharePort feature.
By using D-Link’s unique Smart Antenna design, the Whole Home Router 1000 automatically adjusts its coverage to provide an optimized connection for each authorized wireless client. This extends coverage, minimizes interference, provides higher wireless speeds, and even helps save energy by adjusting the amount of power used for wireless connections. Experience fast, reliable wireless access to the Internet throughout your home or office, even in corners where wireless access was difficult before.
Double the wireless coverage
The Whole Home Router 1000’s multiple antenna design gives you double the wireless coverage when compared to a standard antenna, eliminating dead spots. Connect your devices from farther away than ever before and enjoy a solid connection to your network — inside, outside, and around your house, even across different floors.
Stay safe and secure
Prevent unauthorized access to your network with WPA/WPA2 wireless encryption, which keeps your network traffic secure from prying eyes. You can also set up a Guest Zone to provide limited wireless access on a separate wireless network from your own devices, and wireless scheduling allows you to shut down your wireless network when you are away from your home or office.
General features
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.3
• IEEE 802.3u
• IEEE 802.3ab
WAN connection
• Dynamic IP
• Static IP
• PPPoE
• PPTP
• L2TP
Device Interfaces
• 802.11n/g/b wireless LAN
• 4 10/100/1000BASE-T Gigabit LAN ports
• 1 10/100/1000BASE-T Gigabit WAN port
• USB 2.0 port
Antenna type
• Internal Smart antennas with Smart Beam technology
Security
• WPA & WPA2 (Wi-Fi Protected access)
• 64/128-bit WEP
QoS
• Port-based QoS
Data Rate
• IEEE 802.11b: 11, 5.5, 2, and 1 Mbps
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbps
• IEEE 802.11n for 2.4GHz: 6.5 to 300 Mbps
Transmitter Output Power
• IEEE 802.11b:
 +20 dBm (+/-2dB) at 11, 5.5, 2, and 1 Mbps at room temperature 25°C
• IEEE 802.11g:
  +17 dBm (+/-2dB) at 54, 48, 36, 24 Mbps at room temperature 25°C
  +18 dBm (+/-2dB) at 18, 12, 9, 6 Mbps at room temperature 25°C
• IEEE 802.11n for 2.4 GHz:
  HT20
  18dBm (+/-2dB) at MCS0~ MCS3 and MCS8~ MCS11 at room temperature 25°C
  17dBm (+/-2dB) at MCS4~ MCS7 and MCS12~ MCS15 at room temperature 25°C
  HT40
  17dBm (+/-2dB) at MCS0~ MCS13 and MCS8~ MCS11 at room temperature 25°C
  16dBm (+/-2dB) at MCS4~ MCS7 and MCS12~ MCS15 at room temperature 25°C
Receiver Sensitivity
• IEEE 802.11b:
  at PER=8% (1000-byte PDUs) at room temperature:
  –76 dBm at 11 Mbps
  –76 dBm at 5.5 Mbps
  –80 dBm at 2 Mbps
  –80 dBm at 1 Mbps
• IEEE 802.11g:
  at PER=10% at room temperature:
  –65 dBm at 54 Mbps
  –66 dBm at 48 Mbps
  –70 dBm at 36 Mbps
  –74 dBm at 24 Mbps
  –77 dBm at 18 Mbps
  –79 dBm at 12 Mbps
  –81 dBm at 9 Mbps
  –82 dBm at 6 Mbps
  at PER=10% (1000-byte PDUs) at room temperature 25°C
  HT20(MHz)
  –82 dBm at MCS0/8
  –79 dBm at MCS1/9
  –77 dBm at MCS2/10
  –74 dBm at MCS3/11
  –70 dBm at MCS4/12
  –66 dBm at MCS5/13
  –65 dBm at MCS6/14
  –64 dBm at MCS7/15
• HT40(MHz)
  –79 dBm at MCS0/8
  –76 dBm at MCS1/9
  –74 dBm at MCS2/10
  –71 dBm at MCS3/11
  –67 dBm at MCS4/12
  –63 dBm at MCS5/13
  –62 dBm at MCS6/14
  –61 dBm at MCS7/15
Device management
• Wireless Setup Wizard
• Web-based management using Internet Explorer 6 or later, Firefox 2.0 or later, or another Java-enabled browser
Shareport™ function support
• Allows network sharing of a USB multifunction printer or USB storage drive
LEDs
• Internet
• Wireless
• WPS
• Power
Dimensions
• 120.5 x 198 x 32 mm
Weight
• 341.5 grams
Operating temperature
• 0° to 40°C
Storage temperature
• -20° to 65°C
Operating humidity
• 10% to 90% non-condensing
Storage humidity
• 5% to 95% non-condensing
Certifications
• FCC Class B
• CE
• IC
• C-Tick
• IPv6 Ready
• Wi-Fi Certified
• WMM
• Compatible with Windows 7
Certificates
Order info
DIR-645 Whole Home Router 1000
Pictures
DIR-645A1
Back view
Front view
Downloads
Support Resources
