Quick find
Product features:
Whole Home Router 1000
EOL
Description:
Fast, reliable connections to your devices
The D-link Whole Home Router 1000 allows you to create reliable, high-speed connections to your wired and wireless devices. It features 802.11n wireless with D-link’s unique Smart Beam technology to provide wireless access to the Internet for your entire home or office. It also includes four gigabit LAN ports with easy to use port-based Quality of Service (QoS); simply plug in your wired devices in order of importance, and the Whole Home Router 1000 will automatically configure QoS for you. This allows you to watch smooth streaming video on your media PC or game console while surfing the web or downloading files on a PC. You can even connect a USB printer or storage drive and share it through D-link’s SharePort feature.
By using D-Link’s unique Smart Antenna design, the Whole Home Router 1000 automatically adjusts its coverage to provide an optimized connection for each authorized wireless client. This extends coverage, minimizes interference, provides higher wireless speeds, and even helps save energy by adjusting the amount of power used for wireless connections. Experience fast, reliable wireless access to the Internet throughout your home or office, even in corners where wireless access was difficult before.
Double the wireless coverage
The Whole Home Router 1000’s multiple antenna design gives you double the wireless coverage when compared to a standard antenna, eliminating dead spots. Connect your devices from farther away than ever before and enjoy a solid connection to your network — inside, outside, and around your house, even across different floors.
Stay safe and secure
Prevent unauthorized access to your network with WPA/WPA2 wireless encryption, which keeps your network traffic secure from prying eyes. You can also set up a Guest Zone to provide limited wireless access on a separate wireless network from your own devices, and wireless scheduling allows you to shut down your wireless network when you are away from your home or office.
Products | Support  | News  | About |
