Quick find
Product features:
XTREME N™ DUO GIGABIT ROUTER
EOL
General features:
Standards
+ IEEE 802.11n (draft)
+ IEEE 802.11g
+ IEEE 802.11a
+ IEEE 802.3ab
+ IEEE 802.3u
DEVICE INTERFACES
+ 802.11n (draft) wireless LAN
+ 10/100/1000BASE-T Gigabit WAN port
+ 4 10/100/1000BASE-T Gigabit LAN ports
+ USB 2.0 port
ANTENNA TYPE
3 External 2dBi RP-SMA dipole antennas
SECURITY
+ WPA & WPA2 (Wi-Fi Protected Access)
ADVANCED FIREWALL FEATURES
+ Network Address Translation
+ Stateful Packet Inspection (SPI)
+ VPN Pass-Through/Multi-Sessions PPTP/L2TP/IPSec
QoS
+ QoS Engine for prioritizing traffic
+ Wireless Intelligent Stream Handling (WISH)
SharePortTM FUNCTION SUPPORT
- Allows connection of external hard drive or multifunction printer to USB port
- Allows sharing of HD space, printing and scanning functions*
DEVICE MANAGEMENT
+ UPnP Support
+ DDNS Support
+ Integrated Wireless Security Wizard
+ Windows Connect Now (WCN) support
+ Web-based Management using Internet Explorer v6 or above; Mozilla Firefox v2.0 or above; and other Java-enabled browsers
+ E-mail Notification for triggered events
INSTALLATION
+ Quick Router Setup Utility ²
MINIMUM SYSTEM REQUIREMENTS
+ Computer with:
  - Pentium 3 800GHz or better processor
  - 256MB RAM or higher
  - Windows Vista, XP SP2, 2000, 2003 or Mac OS X v10.4 or higher
  - CD ROM drive
  - SharePortTM Network USB Utility
DISPLAY PANEL
+ 84 x 25.8 mm
+ Black and Blue
LED
Power
DIMENSIONS
120.5 x 198 x 40.9 mm (4.7 x 7.8 x 1.6 inches)
WEIGHT
376 grams (0.83 lbs)
CERTIFICATIONS
+ FCC Class B
+ CE
+ IC
+ C-Tick
+ Wi-Fi a/b/g/n (draft)
+ Wi-Fi Protected Setup (WPS)
+ Certified For Windows Vista
Products | Support  | News  | About |
