DMC-300SC
Description
These converters convert 10/100Mbps 10BASE-T/100BASE-TX Fast Ethernet twisted-pair signals to 100BASE-FX Fast Ethernet multi-mode fiber signals.
Maximum fiber cable distance is 2km. 1 RJ-45 twisted-pair port and 1 fiber port are provided.
- DMC-300SC: the fiber port on this media converter is   the SC connector
General features
	Interface
	Number of Ports
	• 1 x 10/100BASE-TX RJ-45 port
	•  1 x 10/100BASE-FX SC port
	Standards
	• IEEE 802.3 for 10BASE-T/F
	• EEE 802.3u for 100BASE-TX/FX
	Data Transfer Rate
	• Ethernet: 10 Mbps/20 Mbps (halfduplex/full-duplex)
	• Fast Ethernet: 100 Mbps/200 Mbps (half-duplex/full-duplex)
	Duplex Mode
	•  Half-duplex/full-duplex
	Media Types
	• 10BASE-T: 2-pair Cat. 3/4/5/5e, Unshielded Twisted Pair (UTP) (up to 100 m)
	• 10/100BASE-TX: 2-pair Cat. 5/5e, Unshielded Twisted Pair (UTP) (up to 100 m)
	• 100BASE-FX: Multi-mode fiber optic cable with SC connector (up to 2 km)
	Media Exchange Interface
	• Auto-MDI/MDIX
	Functionality
	Transmission Mode
	• Store-and-forward
	Forwarding Rate
	• Full wire-speed forwarding rate
	Management
	• Through the DMC-1000 chassis with the DMC-1002 management module installed
	Management Functions
	• Fiber port duplex mode
	Physical
	Diagnostic LEDs
	• Power
	• Speed (for twisted pair ports)
	• Full-duplex/Collision (for twisted pair and fiber ports)
	• LINK/ACT (for twisted pair ports)
	AC Input
	• 5 V/1 A external power adapter
	Temperature
	• Operating: 0 °C to 40 °C (32 °F to 104 °F)
	• Storage: -25 °C to 70 °C (13 ºF to 158 °F)
	Humidity
	• 10% to 90% RH, non-condensing
	Dimensions
	• 120 x 88 x 25 mm (4.72 x 3.46 x 0.98 in)
	Weight
	• 291 g (0.64 lbs)
	Fiber Wavelength
	• 1310 nm
	Supported Fiber Cable Length
	• Up to 2 km
	Emission Certifications (EMI)
	• FCC Class A
	• VCCI Class A
	• CE Class A
Certificates
Order info
DMC-300SC 10/100BASE-TX Twisted Pair to 100BASE-FX Multi-mode fiber (2 km, SC) Media Converter Module
