Description
Up to 8Mbps Speed
At up to 8Mbps downstream and 640Kbps upstream for full-rate .dmt, and up to 1.5Mbps downstream and 512Kbps upstream for G.Lite, you'll see a startling and immediate increase in performance. The DSL-504 ADSL router operates on the existing telephone line and does not require any new cabling.
Uses Existing Telephone Line
ADSL simply makes better use of the existing wire by partitioning it into different channels or frequencies in order to get more data on the line. The frequency range used by traditional telephones remains untouched, with data travelling at other frequencies. This allows traditional phones and faxes to operate exactly as before without being affected by the high-speed ADSL data transfers which take place at the same time.
No More Busy Signals
ADSL is always on once it is installed, not a problem since ADSL providers don't charge per minute. It simply eliminates the need to dial up to establish a connection to an ISP or a corporate network and makes your online experience that much faster, reliable and convenient.
4 Built-in Switch Ports
The ADSL router comes with 4 built-in 10/100Mbps switched ports, each providing dedicated bandwidth for connected devices/computers. Since devices connected directly to a switch don't compete for local bandwidth, the DSL-504 can help speed up your LAN as well.
