DWA-510EOL EOS
Wireless G Desktop Adapter
Where to buy
Description
BASIC WIRELESS CONNECTIVITY
Connect to your wireless network from your desktop PC using the DWA-510 Wireless G Desktop Adapter and browse the web, check e-mail, and chat with friends and family online. The Wireless G Desktop Adapter offers simple network connectivity without the hassle of running a network cable.
BASIC SECURITY PROTECTION
To protect your data and privacy, the Wireless G Desktop Adapter supports WEP and WPA encryption for connecting to a secure wireless network.
COMPATIBILITY ASSURANCE
The Wireless G Desktop Adapter is based on the 802.11g standard and is backwards compatible with 802.11b, ensuring compatibility with a wide range of wireless routers and networks.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup for this desktop adapter. The addition of the Wi-Fi Protected Setup (WPS) function provides advanced security features that remain simple enough for the average user to confgure correctly. This function allows for devices to undergo an easy one-time click-button confguration for establishing connection with an access point or wireless router without the need of manually setting up complex encryption codes
General features
SYSTEM REQUIREMENTS
+  Windows 98SE, ME, XP SP2, 2000 SP4 or Vista
+  CD-ROM drive CD-ROM drive
+  20MB hard disk space 20MB hard disk space
+  PCI bus slot PCI bus slot
STANDARDS
+  IEEE 802.11g IEEE 802.11g
+  IEEE 802.11b IEEE 802.11b
INTERFACE
PCI 2.3
FREQUENCY RANGE
+  2412 to 2462MHz (North America)
+  2412 to 2472MHz (General Europe)
EMISSION SCHEMES
DSSS, OFDM
DATA MODULATION SCHEMES
DBPSK, DQPSK, DSSS and CCK
(BPSK/QPSK/16-QAM/64-QAM/OFDM)
DATA RATES 1
+  802.11g: 6/9/12/18/24/36/48/54Mbps
+  802.11b: 1/2/5.5/11Mbps 802.11b: 1/2/5.5/11Mbps
ANTENNA
Detachable 2dBi dipole antenna
SECURITY
+  64/128-bit WEP data encryption
+  Wi-Fi Protected Access (WPA/WPA2-PSK, WPA/WPA2-EAP)
+  802.1x
POWER INPUT
3.3 VDC ± 10% or 5VDC ± 10%
POWER CONSUMPTION
+  TX: 450mA
+  RX: 260mA
+  Standby: 15mA
DIAGNOSTIC LED
+  Activity
+  LInk
DIMENSIONS
126 x 12 x 19 mm
OPERATING TEMPERATURE
0˚ to 40˚ C
STORAGE TEMPERATURE
-20˚ to 65˚ C
OPERATING HUMIDITY
10% to 90% non-condensing
STORAGE HUMIDITY
5% to 95% non-condensing
CERTIFICATIONS
+  FCC Class B
+  CE
+  C-Tick
+  IC
+  Wi-Fi
+  WPS Certifed
OS SUPPORT
Windows 98SE, ME, 2000, XP, Vista
1 Maximum wireless signal rate derived from IEEE standard 802.11g specifcations. Actual data throughput will vary. Network conditions and environmental  factors,  including volume of network  traffc, building materials and construction, and network overhead, lower actual data  throughput rate. Environmental  factors will adversely affect wireless signal range.
Certificates
Order info
DWA-510   802.11g Wireless PCI Adapter
Pictures
DWA-510
Front view
Downloads
Support Resources
