Quick find
Product features:
Wireless G Desktop Adapter
EOL
Description:
BASIC WIRELESS CONNECTIVITY
Connect to your wireless network from your desktop PC using the DWA-510 Wireless G Desktop Adapter and browse the web, check e-mail, and chat with friends and family online. The Wireless G Desktop Adapter offers simple network connectivity without the hassle of running a network cable.
BASIC SECURITY PROTECTION
To protect your data and privacy, the Wireless G Desktop Adapter supports WEP and WPA encryption for connecting to a secure wireless network.
COMPATIBILITY ASSURANCE
The Wireless G Desktop Adapter is based on the 802.11g standard and is backwards compatible with 802.11b, ensuring compatibility with a wide range of wireless routers and networks.
EASY TO INSTALL & CONNECT
D-Link’s Quick Setup Wizard provides easy setup for this desktop adapter. The addition of the Wi-Fi Protected Setup (WPS) function provides advanced security features that remain simple enough for the average user to confgure correctly. This function allows for devices to undergo an easy one-time click-button confguration for establishing connection with an access point or wireless router without the need of manually setting up complex encryption codes
Products | Support  | News  | About |
