DAP-1620EOL
AC1200 Wi-Fi Range Extender
Where to buy
Description
The DAP-1620 AC1200 Wi-Fi Range Extender is a portable plug-in repeater that lets you extend an existing wireless network. You can place it anywhere in your home to increase the range of your wireless network. Tiny yet powerful, it supports Wireless AC speeds of up to 1200 Mbps, yet fits in the palm of your hand.
Extend Your Wireless Network
Increase the coverage of your home Wireless AC network with the sleek and easy-to-use DAP-1620 AC1200 Wi-Fi Range Extender. Dual-band technology helps reduce interference from nearby wireless transmitters in the home, and also provides backward compatibility with older wireless devices in your network, allowing you to enjoy a blazing-fast, reliable wireless connection. Alternatively, use the built-in Gigabit Ethernet port and your home’s existing wired Ethernet cabling to extend wireless coverage without worrying about signal strength.
Easy to Set Up, Easy to Use
Setting up the AC1200 Wi-Fi Range Extender is simple. You can use the supported QRS Mobile app on your iPhone, iPad, or iPod touch or Android mobile device to set up the DAP-1620 easily without needing a computer. Alternatively, you can use one-touch configuration by pushing the WPS push-button on the DAP-1620 and on the router or AP you want to extend, and the DAP-1620 will automatically configure itself for you. It even includes a built-in setup wizard that lets you configure it wirelessly with a PC or mobile device.
Compact, Convenient Design
The DAP-1620 is a compact device that is ideal for use at home or a small office, as it does not take up much space and is ready to use by simply plugging it in. The bright Signal Indicator LED makes finding a suitable location a cinch. Its diminutive wall-plug design easily saves you the hassle of dealing with a power cord. Its sleek, unobtrusive appearance blends easily into the decor of your home or office.
General features
Device Interfaces
• 802.11ac/n/g/b/a Wireless LAN
• 10/100/1000 Gigabit Ethernet Port
• Reset Button
• WPS Button
LEDs
• Status/WPS
• 3 Segment Wi-Fi Signal Strength Indicator
Standards
• IEEE 802.11ac
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• IEEE 802.11a
• IEEE 802.3ab
Antennas
• Two external antennas
Data Signal Rate
• 2.4 GHz: Up to 300 Mbps1
• 5 GHz: Up to 867 Mbps1
Plug Type
• Region dependent
Functionality
Wireless Security
• Wi-Fi Protected Access (WPA/WPA2)
• WPS (PBC)
Advanced Features
• D-Link One-Touch Extender Setup
Device Management
• Supports QRS Mobile app for iPhone, iPad, iPod touch, and Android mobile devices
• Web UI
Physical
Dimensions
• 120 x 59 x 42 mm (4.72 x 2.32 x 1.65 inches)
Weight
• 139 grams (4.9 ounces)
Power
• Input: 110 to 240 V AC, 50/60 Hz
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 65 °C (-4 to 149 °F)
Humidity
• Storage: 5% to 95% non-condensing
Certifications
• FCC
• IC
• CE 2
• C-Tick
• EMI/EMC
• UL
• Wi-Fi Certified
1 Maximum wireless signal rate derived from IEEE Standard 802.11ac and 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, may lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
Certificates
Order info
Pictures
DAP-1620
Front view
View from the right
View from the right
Downloads
Support Resources
