DAP-3310
Wireless N Exterior Access Point
Where to buy
Description
The DAP-3310 Wireless N Exterior Access Point is the ideal solution for expanding the coverage and signal strength of any wireless network. Built to withstand harsh environments, the DAP-3310 also excels in connecting separate networks that cannot be joined physically using traditional medium. Multiple operating modes, network management tools, and security features gives network administrators a wide range of choices for deploying the device, allowing for the addition of increased connectivity to wireless network-enabled devices.
Increased network connectivity and throughput
Expand current wireless network capacity with the latest 2.4GHz 802.11n wireless connectivity. In addition, two 10/100 Ethernet ports (one supporting PoE) allow for further physical expansion using traditional wired medium. The built-in 10dBi sector antenna has a high power output ensuring that wireless coverage will cover even hard to reach locations. Whether you want to connect additional wireless devices such as smartphones or laptops, or bringing connectivity to networks separated by short distances, the DAP-3310 has it covered.
Flexible deployment options
The DAP-3310 features seven multiple operation modes, allowing it to adapt to any situation. As a standard wireless access point (AP) the DAP-3310 can connect to a wide range of devices that are 802.11n/g/b compliant. In wireless distribution system (WDS) mode it can expand current wireless coverage without the need for a wired backbone link. As a wireless client it can connect to an existing AP and expand the network physically with the two built-in 10/100 Ethernet ports. Repeater mode will extend current wireless coverage eliminating dead spots and weak signals. WISP mode functionality includes the ability to function as a client or repeat.
Fine-tuned control over network resources.
The DAP-3310 supports up to 8 SSIDs, allowing the administrators to logically divide the access point into several virtual access points all within a single hardware platform. Rather than having separate networks with several access points, administrators can deploy one single AP to support more than one application, such as public Internet access and internal network control to increase flexibility and keep costs down. The DAP-3310 supports 802.1Q VLAN Tagging, operating with multiple SSIDs to segment traffic to enhance performance and security. The DAP-3310 provides WLAN partitioning, a useful function for deployments such as wireless hot spots. With station-to-station partitioning enabled, security is enhanced, since wireless users cannot peek at each other, and the possibility for data theft is reduced.
Robust security and management tools
The DAP-3310 supports 64/128-bit WEP data encryption and WPA/WPA2 security functions. In addition, it provides MAC Address Filtering to control user access, and the Disable SSID Broadcast function to limit outsiders access to the internal network. Network administrators have multiple options for managing the DAP-3310 including HTTP and HTTPS. For advanced network management, administrators can use SNMPv1, v2c, v3 to configure and manage access points.
Power over Ethernet (PoE)
The DAP-3310 is powered by PoE which allows for convenient installation, especially in places where a power supply is not reliable or power cables are not available or easily set up. Also, the DAP-3310 can supply power to a connected D-Link surveillance camera through PoE, including the DCS-3716, DCS-6113, and DCS-7110 cameras.
General features
Device Interfaces
• 802.11n/g/b
• Two 10/100 Ethernet ports (one supports PoE)
• Reset button
• Grounding wire connector
LEDs
• Power
• LAN
• Wireless Signal Strength
Antenna
• Sector antenna with 10dBi gain
Standards
• IEEE 802.11b/g/n
• IEEE 802.3
• IEEE 802.3u
Frequency band
• 802.11b: from 2.4 GHz to 2.497GHz
• 802.11g: from 2.4 GHz to 2.4835GHz
• 802.11n: from 2.4 GHz to 2.4835GHz
Wireless speed
• 802.11b: 11, 5.5, 2, 1 Mbit/s
• 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbit/s
• 802.11n:
  MCS GI=800ns GI=400ns
20MHz 40MHz 20MHz 40MHz
  0 6,5 13,5 7,2 15
  1 13 27 14,4 30
  2 19,5 40,5 21,7 45
  3 26 54 28,9 60
  4 39 81 43,3 90
  5 52 108 57,8 120
  6 58,5 121,5 65,0 135
  7 65 135 72,2 150
  8 13 27 14,444 30
  9 26 54 28,889 60
  10 39 81 43,333 90
  11 52 108 57,778 120
  12 78 162 86,667 180
  13 104 216 115,556 240
  14 117 243 130 170
  15 130 270 144,444 300
The output power of the transmitter
• IEEE 802.11b:
  28 ±2 dBm at 1, 2, 5,5, 11 Mbit/s
• IEEE 802.11g:
  26 ±2 dBm at 6-36 Mbit/s
  24 ±2 dBm at 48 Mbit/s
  23 ±2 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4GHz/HT-20
  26 ±2 dBm at MCS0/8,1/9,2/10,3/11
  25 ±2 dBm at MCS4/12
  24 ±2 dBm at MCS5/13
  23 ±2 dBm at MCS6/14
  22 ±2 dBm at MCS7/15
  2.4GHz/HT-40
  25 ±2 dBm at MCS0/8,1/9,2/10
  25 ±2 dBm at MCS3/11
  24 ±2 dBm at MCS4/12
  23 ±2 dBm at MCS5/13
  22 ±2 dBm at MCS6/14
  21 ±2 dBm at MCS7/15
Receiver sensitivity
• IEEE 802.11b:
  -96 ±2 dBm at 1 Mbit/s
  -94 ±2 dBm at 2 Mbit/s
  -91 ±2 dBm at 5.5 Mbit/s
  -88 ±2 dBm at 11 Mbit/s
• IEEE 802.11g:
  -90 ±2 dBm at 6 Mbit/s
  -89 ±2 dBm at 9 Mbits/s
  -88 ±2 dBm at 12 Mbit/s
  -86 ±2 dBm at 18 Mbit/s
  -84 ±2 dBm at 24 Mbit/s
  -80 ±2 dBm at 36 Mbit/s
  -76 ±2 dBm at 48 Mbit/s
  -74 ±2 dBm at 54 Mbit/s
• IEEE 802.11n:
  2.4GHz/HT-20
  -90 ±2 dBm at MCS0/8
  -88 ±2 dBm at MCS1/9
  -86 ±2 dBm at MCS2/10
  -82 ±2 dBm at MCS3/11
  -78 ±2 dBm at MCS4/12
  -75 ±2 dBm at MCS5/13
  -74 ±2 dBm at MCS6/14
  -72 ±2 dBm at MCS7/15
  2.4GHz/HT-40
  -85 ±2 dBm at MCS1/9
  -83 ±2 dBm at MCS2/10
  -80 ±2 dBm at MCS3/11
  -76 ±2 dBm at MCS4/12
  -72 ±2 dBm at MCS5/13
  -71 ±2 dBm at MCS6/14
  -69 ±2 dBm at MCS7/15
Operation modes
• AP
• WDS
• WDS access point
• Wireless client
• Repeater
• WISP Repeater
• WISP Client Router
Network management
• Web interface
• HTTP - Secure HTTP (HTTPS)
• SNMP v1, v2c, v3
Security
• WPA2-Personal/Enterprise
• WPA-Personal/Enterprise
• 64/128-bit WEP encryption
• 802.1X
SSID/VLAN
• Supports up to 8 SSID/VLAN
Dimensions
• 118 x 56 x 195mm
Weight
• 305g
Operating voltage
• 48VDC ±10% for PoE
Max. power consumption
• 13.5W
Temperature
• Operating: -20° to 60°C
• Storage: -20° to 85°C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
ESD-protection
• 15kV
Certifications
• CE
• FCC
Certificates
Order info
Pictures
DAP-3310/A1
Front view
View from the right
Back view
Вид снизу
Downloads
Support Resources
