DAP-3690EOL EOS
AirPremier N Concurrent Dual Band PoE Outdoor AP
Description
Overview
D-Link introduces its new AirPremier N Concurrent Outdoor Dual Band PoE Access Point (DAP-3690). With its versatile functions, high power design** and weather resistant features, DAP-3690 is an ideal solution for hot spot networks to provide outdoor users with wireless Internet access. It can also be installed in a number of environments, including manufacturing plants, industrial locations, convention halls, school campuses, airports, golf courses, marinas, and other outdoor venues.
Versatile Access Point
The DAP-3690 allows network administrators to deploy a highly manageable and extremely robust concurrent dual band wireless network. All four antennas are detachable and can provide optimal wireless coverage in both 2.4GHz (802.11g and 802.11n) and 5GHz (802.11a and 802.11n) bands. Ideal for outdoor deployment, this device is built with a series of weather resistant features, such as a built in heater, to withstand all elements. For advanced installation, this new high-speed access point has integrated 802.3at Power over Ethernet (PoE) support, allowing installation in areas where power outlets are not readily available.
Multiple Operation Modes
The DAP-3690 can be configured to optimize network performance based on any one of its multiple operation modes: Access Point, Wireless Distribution System (WDS) with Access Point, WDS, and Wireless Client. Also included are advanced features such as Load Balancing, which optimizes high network traffic volume, and redundancy for fail-safe wireless connectivity. Additionally, the DAP-3690 offers Spanning Tree Protocol support for greater efficiency and to avoid broadcast storms when used in WDS mode.
Enhanced Performance
The DAP-3690 delivers reliable wireless performance with maximum wireless signal rate of up to 300 Mbps in both the 2.4 GHz and 5 GHz wireless band.* Additionally, support for Wi-Fi Multimedia™ (WMM) Quality of Service (QoS) features, make this device an ideal access point for audio, video, and voice applications. When enabled, QoS allows the DAP-3690 to automatically prioritize traffic according to the level of interactive streaming, such as Voice over IP (VoIP). The QoS feature also provides a drop-down menu option to customize priority settings. The load balance feature in this device also ensures maximum performance by setting a limit for the total number of users per access point.
Security
To help maintain a secure wireless network, the DAP-3690 provides the latest in wireless security technologies by supporting both Personal and Enterprise versions of WPA™ and WPA2™ (802.11i) with support for a RADIUS server backend. To further protect your wireless network, MAC Address Filtering, Wireless LAN Segmentation, Disable SSID Broadcast, Rogue AP Detection, and Wireless Broadcast Scheduling are also included. The DAP-3690 includes support for up to 16 VLANs per band to implement multiple SSIDs to further help segment users on the network. It also includes a wireless client isolation mechanism, which limits direct client-to-client communication.
Network Management
Network administrators have multiple options for securely managing the DAP-3690 including Web (HTTP), Secure Sockets Layer (SSL), Secure Shell (SSH), and Telnet (bi-directional, eight-bit oriented communications facility) and an RJ-45 console port. For advanced network management, administrators can use the D-Link AP Manager II, AP Array, or D-View SNMPv3 management module to configure and manage multiple access points from a single location. In addition to a streamlined management process, both AP Manager II and D-View provide network administrators with the means to verify and conduct regular maintenance checks remotely, eliminating the need to send out personnel to physically verify proper operation.
With simultaneous dual band functionality, PoE support, extensive manageability, versatile operation modes, and solid security enhancements, the D-Link AirPremier N Concurrent Dual Band Outdoor PoE Access Point (DAP-3690) provides SMB and enterprise environments with a business-class solution for deploying a wireless network in outdoor environment.
General features
Standards
• IEEE 802.11a
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.3ab
• IEEE 802.3at
• IEEE 802.3u
• IEEE 802.3
Network Management
• Telnet, Secure Telnet (SSH)
• Web Browser Interface
• HTTP, Secure HTTP (HTTPS)
• SNMP Support
• D-View Module - Private MIB
• AP Manager II
• AP Array
Security
• WPA™-Personal
• WPA-Enterprise
• WPA2™-Personal
• WPA2-Enterprise
• 64/128-bit WEP
• SSID Broadcast Disable
• MAC Address Access Control
• Rogue AP Detection
• 802.1x Authentication
• Wireless LAN Partition
VLAN/SSID Support
• Multiple SSID supports up to 16 (8 per radio)
Quality of Service (QoS) 4 Priority Queues
• WMM Wireless Priority
Wireless Frequency Range**
• 2.4 GHz (2.4 GHz to 2.4835 GHz)
• 5 GHz (5.15 GHz to 5.35 GHz, 5.47 GHz to 5.85 GHz)
Wireless Speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• IEEE 802.11b: 11, 5.5, 2, и 1 Mbit/s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit/s
• 802.11n:
MCS GI=800ns GI=800ns GI=400ns
20MHz 40MHz 40MHz
0 6.5 13.5 15
1 13 27 30
2 19.5 40.5 45
3 26 54 60
4 39 81 90
5 52 108 120
6 58.5 121.5 135
7 65 135 150
8 13 27 30
9 26 54 60
10 39 81 90
11 52 108 120
12 78 162 180
13 104 216 240
14 117 243 170
15 130 270 300
Transmitter Output Power
• IEEE 802.11a:
+20 dBm at 6-24 Mbit/s
+19 dBm at 36 Mbit/s
+18 dBm at 48 Mbit/s
+17 dBm at 54 Mbit/s
• IEEE 802.11b:
+17 dBm at 11, 5.5, 2 и 1 Mbit/s
• IEEE 802.11g:
+17 dBm at 6-24 Mbit/s
+15 dBm at 36 Mbit/s
+14 dBm at 48 Mbit/s
+13 dBm at 54 Mbit/s
• IEEE 802.11n:
5GHz/HT-20
17 dBm at MCS0/8, MCS1/9, MCS2/10, MCS3/11
16 dBm at MCS4/12
15 dBm at MCS5/13
14 dBm at MCS6/14
11 dBm at MCS7/15 (5.18 – 5.5 ГГц)
9 dBm at MCS7/15 (5.7 – 5.825 ГГц)
5GHz/HT-40
16 dBm at MCS4/12
15 dBm at MCS5/13
14 dBm at MCS6/14
9 dBm at MCS7/15 (5.18 – 5.5 ГГц)
8 dBm at MCS7/15 (5.7 – 5.825 ГГц)
2.4GHz/HT-20
16dBm at MCS0/8, MCS1/9, MCS2/10, MCS3/11, MCS4/12
14dBm at MCS 5/13
13dBm at MCS 6/14
12dBm при MCS 7/15
2.4GHz/HT-40
14dBm at MCS0/8, MCS1/9, MCS2/10, MCS3/11, MCS4/12
13dBm at MCS 5/13
12dBm at MCS 6/14
11dBm at MCS 7/15
Receiver Sensitivity
• IEEE 802.11a:
–82dBm at 6 Mbit/s
–81dBm at 9 Mbit/s
–79dBm at 12 Mbit/s
–77dBm at 18 Mbit/s
–74dBm at 24 Mbit/s
–70dBm at 36 Mbit/s
–66dBm at 48 Mbit/s
–65dBm at 54 Mbit/s
• IEEE 802.11b:
–80dBm at 1~2 Mbit/s
–76dBm at 5.5~11 Mbit/s
• IEEE 802.11g:
–82dBm at 6 Mbit/s
–81dBm at 9 Mbit/s
–79dBm at 12 Mbit/s
–77dBm at 18 Mbit/s
–74dBm at 24 Mbit/s
–70dBm at 36 Mbit/s
–66dBm at 48 Mbit/s
–65dBm at 54 Mbit/s
• IEEE 802.11n:
5GHz/HT-20
–82dBm at MCS0/8
–79dBm at MCS1/9
–77dBm at MCS2/10
–74dBm at MCS3/11
–70dBm at MCS4/12
–66dBm at MCS5/13
–65dBm at MCS6/14
–64dBm at MCS7/15
5GHz/HT-40
–79dBm at MCS0/8
–76dBm at MCS1/9
–74dBm at MCS2/10
–71dBm at MCS3/11
–67dBm at MCS4/12
–63dBm at MCS5/13
–62dBm at MCS6/14
–61dBm at MCS7/15
2.4GHz/HT-20
-82dBm at MCS0
-79dBm at MCS1
-77dBm at MCS2
-74dBm at MCS3
-70dBm at MCS4
-66dBm at MCS5
-65dBm at MCS6
-64dBm at MCS7
2.4GHz/HT-40
-79dBm at MCS0
-76dBm at MCS1
-74dBm at MCS2
-71dBm at MCS3
-67dBm at MCS4
-63dBm at MCS5
-62dBm at MCS6
-61dBm at MCS7
Operating Modes
• Access Point (AP)
• WDS with AP
• WDS
• Wireless Client
Dipole Antenna Gain
• 5 dBi @2.4 GHz
• 7 dBi @5 GHz
Maximum Output Power***
• 20 dBm @2.4 GHz (dual chain)
• 23 dBm @5 GHz (dual chain)
Certificates
Order info
DAP-3690 AirPremier N Concurrent Dual Band PoE Outdoor AP
Pictures
DAP-3690/Ax
View from the right
Back view
Front view
Left side view
Downloads
Support Resources
