DWA-131EOL EOS
Wireless 802.11n nano USB adapter, compact size
Where to buy
Description
SUPERIOR WIRELESS COVERAGE
D-Link DWA-131 Wireless N Nano USB Adapter provides superior wireless signal for your computer compared to the existing wireless 802.11g technology. This Wireless N adapter is ideal for day-to-day activities such as transferring fi les, browsing the Internet, and downloading music. D-Link Wireless N products use smart Antenna technology to transmit multiple streams of data allowing you to receive wireless signals from the farthest corners of your home. Furthermore, D-Link Wireless N technology extends your wireless range, while maintaining compatibility with all your existing 802.11b/g wireless routers and access points.
EASY TO SET UP
The Quick Setup Wizard provides an easy way to setup your USB adapter and the Wireless Manager included with this product helps keep track of all your most frequently accessed networks.
COMPACT AND CONVENIENT
The DWA-131 easily connects your desktop or notebook PC to a wireless network for Internet access and fi le sharing. Wi-Fi Protected Setup (WPS) feature enables devices to establish an easy, one-time, single-click connection with an access point or wireless router, eliminating complex encryption codes. WPS also offers advanced security features that are simple and easy to confi gure. With its unique ‘Firefl y’ design and unmatched performance, this ultra-portable USB adapter is an ideal choice for setting up a secure wireless connection.
General features
STANDARDS
• IEEE 802.11n (draft 2.0)
• IEEE 802.11b
• IEEE 802.11g
INTERFACE
USB 2.0
FREQUENCY RANGE
2.4GHz to 2.4835GHz
ANTENNA
PIFA antenna
SECURITY
• WEP
• WiFi Protection Access (WPA & WPA2)
• WiFi Protection Setup
• PBC/PIN
LED
Link/Activity
CERTIFICATIONS
• FCC Class B
• IC
• Wi-Fi
• CE
• C-Tick
• Windows Vista certified
OPERATING TEMPERATURE
0˚ to 40˚C (32˚ to 104˚F)
OPERATING HUMIDITY
10 ~ 90% (Non-condensing)
DIMENSIONS
18(W) x 34.4(D) x 7.7(H) mm (0.7 x 1.4 x 0.3 inches)
WEIGHT
3.1g (0.007lbs)
OS SUPPORT
Windows 2000, XP, Vista (32/64 bit)
1 Maximum wireless signal rate derived from IEEE Standard 802.11g and draft 802.11n specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range. Wireless range and speed rates are D-Link relative performance measurements based on the wireless range and speed rates of D-Link products.
This product is based on IEEE draft 2.0 802.11n specifications and is not guaranteed to be forward compatible with future versions of IEEE 802.11n specifications. Compatibility with draft 802.11n devices from other manufacturers that are not Wi-Fi® certified is not guaranteed. All references to speed and range are for comparison purposes only. Product specifications, size, and shape are subject to change without notice, and actual product appearance may differ from that depicted herein.
Certificates
Order info
DWA-131  Wireless 802.11n nano USB adapter, compact size
Pictures
DWA-131/A1
Front view
Front view
Downloads
Support Resources
