![](/up/prod/600/DCS-4614EK_A1.jpg)
DCS-4614EKEOL EOS
Vigilance 4 Megapixel H.265 Outdoor Dome Camera
Description
The D-Link DCS-4614EK Vigilance 4 Megapixel H.265 Outdoor Dome Camera is a high-definition professional surveillance solution suitable for small, medium, and large enterprises. The camera uses a high-sensitivity 1/2.8” 4-megapixel progressive scan CMOS sensor with onboard WDR image enhancement to deliver truly superior quality video in all conditions. The all-in-one rugged design makes this camera extremely reliable and ideal for deployment in surveillance applications without the need for additional accessories.
High-Quality Streaming & Recording
To maximize bandwidth efficiency and improve image quality, the DCS-4614EK provides real-time video compression using the H.265, H.264, and MJPEG codecs, and supports two separate profiles for simultaneous video streaming and recording. Video resolutions of up to 2592 x 1520 provide clear details.
Versatile Monitoring in All Environments
The DCS-4614EK features WDR image enhancement to deliver improved image quality in conditions with uneven or difficult lighting, so you can identify subjects that are backlit or in brightly-lit areas. In low-light situations, the IR-cut filter automatically slides out of the way to use all available light. The DCS-4614EK also has built-in IR LED illuminators with a 30-meter range, allowing the camera to keep watch even in complete darkness. IP66 certification ensures the camera is completely protected from dust and water in any environment. These features work together to give you a reliable surveillance camera capable of monitoring indoors or outdoors 24/7.
Robust Management Software
The DCS-4614EK Vigilance 4 Megapixel H.265 Outdoor Dome Camera supports D-ViewCam, a complete surveillance software package that enables you to view, manage, and record from several cameras on a single computer in a central location. Recordings and e-mail alerts can be triggered upon motion detection or by digital input devices. This feature automatically keeps a record of any unusual activity and notifies administrators when no one is around to monitor on-site.
Flexible Connectivity
The DCS-4614EK has built-in 802.3af-compliant PoE support that simplifies installation by providing power and networking connectivity over a single standard network cable: This feature can speed along installation by reducing the need to lay extra electrical wiring and install outlets in the location since a motion detection or by digital input devices. This feature automatically keeps power supply is not required.
General features
Interfaces
• 10/100 BASE-TX Ethernet port with PoE (Class 3)
• microSD card slot (SD/SDHC/SDXC)1
• Reset button
Camera Hardware Profile
• 1/2.8” 4-megapixel progressive CMOS sensor
• 30 meter smart IR illumination distance
• Built-in Infrared-Cut Removable (ICR) Filter module
• Minimum illumination:
- Color: 0.05 lux @(F2.0, AGC ON)
- B/W: 0 lux @(IR LED ON)
• Minimum object distance 0.5 m
• Focal length: 2.8 mm
• Aperture: F2.0
• 18x digital zoom
• Angle of view:
- (H) 100°
- (V) 58°
- (D) 126°
• 3-axis adjustment angle (non-motorized):
- Pan: 15° - 90°
- Tilt: 350°
- Rotate: 335°
Camera Housing
• IP66 compliant weatherproof housing
• IK10 vandal-proof certified
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable shutter speed/brightness/saturation/contrast/sharpness/3D filter
• Configurable motion detection area
• Configurable privacy mask zones
• Auto White Balance (AWB)
• Auto Gain Control (AGC)
• Wide Dynamic Range (WDR)
• Corridor mode
Video Compression
• Simultaneous H.265/H.264/MJPEG format compression
• JPEG for still images
Video Resolution
• 2592 ? 1520 at up to 30 fps
Network
Network Protocols
• IPv4
• HTTP/HTTPS
• RTSP/RTP/RTCP
• TCP
• UDP
• DHCP
• DNS
• DDNS
• NTP
• FTP
• SMTP Client
• ONVIF Profile S compliant
• ARP
• ICMP
• PPPoE
• SNMP v1/v2c/v3
System Management
Event Management
• Motion detection
• Multiple event notifications
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Event video recording via microSD card, D-ViewCam, D-Link NVR or ONVIF-compliant NAS
Remote Management
• Remote management via D-ViewCam software
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
System Requirements for Web Interface
• Operating System: Microsoft Windows
• Browser: Internet Explorer 11 for full function; Chrome and Firefox (MJPEG only)
D-ViewCamTM System Requirements
• Operating System: Windows 10
• Protocol: Standard TCP/IP
D-ViewCamTM Software Functions
• Remote management/control of up to several cameras
• Supports all management functions provided in web interface
• Viewing of up to several cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical Parameters
Weight
• 390 g ± 5%
Dimensions
• 110 mm x 110 mm x 85.4 mm (4.3 in x 4.3 in x 3.4 in)
Environmental
Power
• External power adapter: 100 to 240 V AC, 50/60 Hz (Input), 12 V DC 1.5 A (Output)
Power Consumption
• 8 W ± 5% (PoE)
Temperature
• Operating: -40 to 50 °C (-40 to 122 °F)
• Storage: -20 to 70 °C (-40 to 158 °F)
Humidity
• Operating: Max. 90% non-condensing
• Storage: Max. 90% non-condensing
Package Content
• Vigilance Outdoor Dome Camera
• Cable Waterproofing Connector
• Mounting Kit
• Allen Key
• Alignment Sticker
• Documentation
Certifications
• CE
• FCC
• RCM
1microSD card not included. Supports capacity up to 256 GB.
Certificates
Order info
