DCS-2530LEOL
Full HD 180-Degree Wi-Fi Network Camera
Where to buy
Description
The DCS-2530L Full HD 180-Degree Wi-Fi Network Camera boasts a horizon-wide 180° lens that easily captures your entire room, wall-to-wall, in high-quality 1080P. Its rotatable head makes ceiling installations easy, and the built-in night vision, motion and sound detection, and handy mobile app empower you with knowing exactly what is happening, day or night.
Peace Of Mind With 24/7 Complete Coverage
Unlike traditional cameras, the DCS-2530L uses an ultra-wide view lens to give you a full 180° field of view, letting you cover an entire room with a single camera. Send e-mail notifications with snapshots or video clips whenever motion or sound is detected using just the DCS-2530L and an Internet connection. Built-in motion detection keeps you aware of what’s happening, and you can set volume limits to detect when a loud sound is picked up by the camera. Night time monitoring is possible with the built-in infrared LEDs which allow for night time viewing of up to 5 meters (16 feet), enabling round-the-clock monitoring of a home or small office.
Place It Anywhere In Your Home
When setting up a surveillance camera, you need to make sure that it can provide smooth video wherever you decide to install it. The DCS-2530L has built-in Wireless N to give you a high bandwidth connection to your router, allowing it to stream HD video with ease. The Signal Locator LED tells you how strong the camera’s wireless connection is, making it easy to optimize the placement of your camera.
Instant Anywhere Access With mydlink Cloud Service
Enhanced with mydlinkTM support, the DCS-2530L makes it easier and convenient for you to look after your family and check on your home or office. With a mydlink service enabled camera, you can stay connected to everything you love from anywhere, anytime. Access your camera through the mydlink website or the mydlink mobile app that lets you view and manage your camera through your tablet or mobile phone, no matter where you are.
General features
Camera Hardware Profile
• 1/3  2 Megapixel progressive CMOS sensor
• Minimum illumination:
Color mode: 0.5 lux
B/W mode (LEDs off): 0.1 lux
B/W mode (LEDs on): 0 lux
• Minimum object distance 30 cm
• Lens focal length: 1.7 mm
• Aperture: F2.5
• Angle of view (16:9):
(H) 180°
(V) 86°
(D) 180°
• Stand angle: -15° to 90°
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Wide Dynamic Range (WDR)
• 3D filtering
• Time stamp and text overlays
• Configurable motion detection windows
• Configurable privacy mask zones
• Configurable exposure time, brightness, saturation, contrast, sharpness.
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264 multicast streaming
• JPEG for still images
Video Resolution
• 16:9
1920 x 1080 at up to 15 fps
1280 x 720, 800 x 448, 640 x 360 at up to 30 fps
Audio Support
• G.711 128 Kbps
• AAC 32 Kbps
Connectivity
• 802.11n/g/b wireless with WPA/WPA2 encryption
• Operates on 2.4 GHz band
• Maximum data rate of 155 MBps (PHY rate)
• micro SD/SDHC/SDXC card Slot, accepts cards up to 128 GB
Network Protocols
• IPv6, IPv4, ARP, TCP, UDP, ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• DDNS client (D-Link)
• SMTP client
• HTTP server
• UPnP port forwarding
• RTP/RTSP/RTCP
• HTTPS (for configuration)
• ONVIF
• Bonjour
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP digest encryption
System Requirements for Web Interface
• Operating System: Windows 10/8/7 or Mac OS X 10.7 or higher
• Browser: Internet Explorer 8, Firefox 12, Chrome 20, or Safari 6 or higher
Event Management
• Motion detection
• Sound level detection
• Scheduled recording
• Event notification and uploading of snapshots/video clips via e-mail
Remote Management
• Configuration interface accessible via web browser
Mobile Support
• mydlink Lite app for iPhone, iPad, iPod Touch, Android, and Windows
• mydlink+ app for iPad and Android
Dimensions
• 109.6 x 66.0 x 66.0 mm ± 5%
Weight
• 105 grams ± 5%
Power Adapter
• Input: 100 to 240 V AC, 50/60 Hz
Power Consumption
• 4.5 watts ± 5%
Temperature
• Operating: 0 to 40°C
• Storage: -20 to 70°C
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• ICES
Certificates
Order info
Pictures
DCS-2530L/Ax
Left side view
View from the right
Front view
Downloads
Support Resources
