Quick find
Product features:
mydlink Network Video Recorder
EOL EOS
General features:
Software specifications
OS
• Linux
Supported cameras
• Supports all D-Link network cameras. Includes support for auto-discovery, and up to 3 megapixel resolution.
Recording performance
• Max. capacity (NVR mode only):
H.264 1080P (bitrate): 90 Mbps
H.264 720P (bitrate): 90 Mbps
MJPEG 1080P (frame rate): 90 fps
MJPEG 720P (frame rate): 192 fps
• Max. capacity (NVR + File Server mode):
H.264 1080P (bitrate): 68 Mbps
H.264 720P (bitrate): 68 Mbps
MJPEG 1080P (frame rate): 70 fps
MJPEG 720P (frame rate): 150 fps
Camera Search
• UPnP
Audio and video recording
• Synchronized audio & video recording
Compression Format
• H.264, MPEG-4, M-JPEG (for supported cameras)
Video settings
• Resolution, quality, frame rate, enable audio, go to camera interface
Recording type
• Record by schedule, manual, and event-based recording
• Motion-triggered recording
Remote live view
• Supported via Internet Explorer (max. 9 simultaneous channels)
• Supports mydlink portal (max. 1 simultaneous channel)
Remote live view control
• Live view, preset/go, patrol, focus, PTZ functions, snapshot, full
screen, digital zoom, e-map, multiple view (1/4/6/9/16/25/36/48) with duplicated carrier
Remote playback control
• Playback with normal, fast forward/rewind and step forward/rewind
Remote playback
• Supported via Internet Explorer and NVR client
• Playback system with timeline GUI, search by event, area, cameras, date and time
• IE and NVR client support 1-channel
• Digital zoom
Overwrite recording
• Auto recycling when disk storage is full
File export
• Export videos to AVI or ASF file
• Export images to BMP and JPG file
User account
• Additional accounts can be created to allow user access to the system, and specify authorization for camera channels, PTZ, etc
System time
• Set the system time (D-Link NTP, input time, sync with your computer, Daylight Saving Time)
DDNS
• D-Link DDNS server support
Remote backup
• Remote software can backup raw data to redundant storage
• Auto backup of previous day's video to FTP server
System status
• Camera status, system status
• Still picture EMAP support
Network protocols
• IPV4, ARP, TCP, UDP, ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• HTTP Server
• PPPoE
• UPnP
• IP filtering
User interface
• mydlink web portal - Internet Explorer 7 or newer
• HTTP Web browser - Internet Explorer 7 or newer (32 bit OS only)
• NVR Search Utility
Hardware specifications
Standards
• IEEE 802.3/u/z
• Auto MDI/MDI-X
• SATA I, II
HDD (Hard Disk Drive)*
• Hard disk control & management via PC
• Reformat disk
• RAID 0**
• RAID 1**
• JBOD
Two reset modes
• Reset firmware GUI button
• HW reset button (hold for 5 seconds)
Flash ROM
• 128 MB
RAM
• 128 MB DDR II
Network interface
• Gigabit Ethernet LAN port (10/100/1000 Mbps)
I/O Ports
• RJ-45 port
• DC-in jack
• USB port for UPS status update (optional)
Power adapter
• DC 12 V/4 A
Reset button
• Reset to factory defaults
Security
• Device lock hole
Power consumption
• Max. power consumption: 25.20 W
• Standby state max. power consumption: 0.23 W
Dimensions
• 115 x 146.4 x 178.5 mm
Weight
• 0.875 kg
Operating temperature
• 0° to 55°C
Storage temperature
• -20° to 70°C
Humidity
• 5% to 90% (non-condensing)
Certifications
• CE
• FCC
• RoHS
Package contents
• DNR-322L 2-bay mydlink NVR
• Power adapter
• Ethernet cable
• Quick Installation Guide
• Power cable holder
• CD-ROM with:
Software
Product documentation
* Hard disks are not included.
** RAID 0 and RAID 1 mirroring requires the use of two internal SATA drives. To avoid data incompatibility in RAID 1 operation, use identical SATA drives from the same manufacturer. Formatted drive capacity for RAID 1 operation is dependent on the drive capacity of the lowest-sized drive. Some older generation SATA drives may not be compatible. For a list of SATA drives that have been tested to work with the NVR, visit the D-Link support website.
Products | Support  | News  | About |
