Quick find
Product features:
Securicam Network 802.11g Wireless Internet Camera
EOL EOS
General features:
Hardware & System
RAM
8MB
Flash
2MB
O. S. Support
Windows 98SE, ME, 2000, XP
Browser Support
Internet Explorer v.6 & Above, Nescape Navigator v.7
Network Connection
- Ethernet: 10/100BASE-TX Port
- Wireless LAN
- Standard: 802.11g
- Data Rates: Up to 54Mbps
- Antennas: 2dBi Gain Detachable Diversity Antenna (RP-SMA Connector)
- Transmitter Output Power: 15 dBm +/- 2 dB
Software Functions
- Communication Protocols: TCP/IP, UDP, HTTP, SMTP, FTP, Telent, NTP, DNS, DHCP, ARP, ICMP, BOOTP
- Universal Plug and Play (UPnP)
- Dynamic DNS Services (DDNS)
- Time Synchronisation With NTP Server
- Text, Date & Time Overlay
- Playback Schemes: Date, Time Interval, Event Triggering
- View Snapshots
- Save Snapshots
- Motion Detection Alarm
- Email Notification
Management & Firmware Updates
- Management Site: Local & Remote
- Using Web Browser
- Using FTP Application
- Max. Cameras on Single Screen*: 16
- Reset Button
- Max. Users Accessing Camera Simultaneously: 10
Camera Specifications
- Lens (Focal Length, Aperture): 6.0mm, f1.8
- Sensor Resolution: 640 x 480
- Image Sensor: 1/4-imch Color CMOS Sensor, Progressive Scan Mode
- Lens Type: Fixed Lens
- Illumination: Min. 2.5 lux
- Automatic Gain Control (AGC): 24dB
- Automatic White Balance (AWB)
- Automatic Exposure (AE)
- Back Light Compensation (BLC)
- Electronic Shutter
- Shutter Speed: 1/60 to 1/150000 secretary
Video
- Color Selection: Color
- Image Frame Rate: Up to 30fps
- Image Compression: MJPEG
- Compression Ratios: 5 Levels
- Resolution: 160 x 120 @ 30fps, 320 x 240 @ 25fps, 640 x 480 @ 10fps
- Viewing System Required Protocol: ActiveX & Java
- Scheduled Recording
- Brightness Control
- Contrast Control
- Saturation
Audio
- Built-in Microphone
- Sampling Rate: 8Kbps
- Audio Recording
1. Specifications applied to DCS-900 hardware version B1 only.
2. Up to 4 cameras using IPView SE surveillance/management software, up to 16 cameras using D-ViewCam surveillance/management software.
Diagnostic LEDs
- Power
- Activity
Input Power
- 5VDC, 2.5A
- Through External Power Adapter
Dimensions
- 66mm (diameter) x 73mm (height) (camera only)
- 66mm (diameter) x 135mm (height) (including camera stand)
Weight
130 grams
Operating Temperature
0  to 50 C
Storage Temperature
-25 to 60 C
Humididy
Max. 95% RH, non-condensing
EMC
- FCC Class B
- CE
- C-Tick
- IC
Safety
LVD (En60950)
Products | Support  | News  | About |
