Quick find
Product features:
Megapixel Day & Night WDR Network camera
EOL EOS
Description:
High resolution Surveillance
The D-link DCS-3710 is a high-end Megapixel Day & Night WDR Network Camera, equipped with a 1/3” Megapixel WDR progressive Scan CMOS and a 2.8~12 mm DC auto iris lens. The DCS-3710 captures video in both dark and light environments, or even subjects shot against a backlight by neutralizing and generating a realistic image. In addition, the removable IR-cut filter for day/night functionality provides clear details and high quality video at any hour of the day. The DCS-3710 incorporates power over Ethernet (PoE) and an SD card slot. Consequently, it can be easily installed in a variety of locations.
Multiple video streams
The DCS-3710 supports simultaneous streaming of MPEG-4 and MJPEG video to provide both high-quality, and bandwidth-efficient compression formats. MJPEG delivers excellent file integrity, ideal for situations which required high image detail. Mpeg-4 produces a small file size, making it more useful for extended recording or for use in low bandwidth networks. Additionally, the DCS-3710 supports multicast MPEG-4 streaming allowing users to view contact by subscribing to a multicast IP address on the network.
Flexible Connectivity
The DCS-3710 include input and output ports allowing connectivity to external devices such as IR sensors, switches, and alarm relays. It also comes with a RS-485 interface, providing connectivity to an optional pan/tilt enclosure, which effectively adds pan/tilt functionality to the DCS-3710. Additionally, a 12 V interface provides power for an optional LED illuminator.
Wide dynamic range (WDR) applications
the Wide Dynamic Range (WDR) function of a camera provides clear images even under backlit conditions where the intensity of illumination can vary significantly. the DCS-3710 is recommended for extreme high-contrast environments. For example, when placed indoors, the DCS-3710 will adjust itself to the intense sunlight that may be streaming in through a nearby window. this makes it an ideal solution for security applications.
Products | Support  | News  | About |
