DWL-3600APEOL EOS
Unified N Access Point
Where to buy
Description
The DWL-3600AP Unified 802.11n Access Point is an indoor 802.11n Wi-Fi access point designed specifically for deployment in business environments. Highly manageable and capable of high data transmission speeds, the DWL-3600AP integrates seamlessly into existing network infrastructure and can be easily scaled up to meet future demands.
High Performance
The DWL-3600AP’s 2x2 MIMO 2.4GHz radio delivers up to 300 Mbps*of network throughput. In addition, the DWL-3600AP features RadioProtect technology, which ensures all users receive an adequate level of service even in an environment where many users are accessing the network through legacy 802.11b and 802.11g devices.
Self-Configuring Cluster
For small businesses that need to deploy multiple access points (APs) but lack the resources to tackle the complicated task of network management, the DWL-3600AP’s self-configuring cluster feature offers the ideal solution. When a small number of DWL-3600APs is deployed on the network, they may be configured to form a self-configuring cluster. Once the administrator is through with configuring one access point, the same configuration can then be applied to all remaining APs. Up to 16 APs may be used to form a cluster.
Unified Management
When deployed in conjunction with D-Link’s line of Unified Wireless Switches, up to 256 DWL-3600AP units may be centrally managed and provisioned, thus enabling the administrator to expand the Wi-Fi network to cover a large area.
Security
The DWL-3600AP supports the latest standards in Wi-Fi security, including WPA, WPA2, and 802.1X. In addition, the DWL-3600AP supports up to 16 virtual access points (VAP), which allows the administrator to assign different access privileges to different groups of users. When used together with D-Link’s line of Unified Wireless Switches, security can be raised to a new level. Rogue APs in the network may be easily detected, and the administrator will be immediately notified of any security threat.
Automatic RF Management
When a number of access points are deployed close to each other, interference may result if proper RF management is not implemented. When a DWL-3600AP senses a neighbor nearby, it will automatically select a non-interfering channel. This greatly reduces RF interference and will allow the administrator to deploy APs more densely. To further minimize
interference, when a nearby AP is operating on the same channel, the DWL-3600AP will automatically lower its transmission power. When, for whatever reason, the nearby AP is no longer present, the DWL-3600AP will increase its transmit power to expand coverage.
Quality of Service
The DWL-3600AP is WMM-certified, so in the event of network congestion, time-sensitive traffic can be given priority ahead of the rest of traffic. Furthermore, when a number of DWL-3600APs are in close proximity with each other, an access point will refuse new association requests once its resources are fully utilized. Instead, the association request will be picked up by a neighboring unit. This feature ensures that no single AP is overburdened while others nearby sit idle.
General features
Power
• Power Adapter: 5V/2.5A
• Power over Ethernet: 48V DC +/-10%
Enclosure Type
• PC or plenum-rated chassis
Enclosure Size
• 203 x 203 x 48mm
Weight
• Standard chassis: 550g
• Plenum-rated chassis: 635g
Operation Temperature
• 0 to 40°C
Operation Humidity
• 10% to 90% non-condensing
Safety
• cUL, LVD (EN60950-1), UL2043 (for plenum-rated sku only)
Compliance
• EMI/EMC/RF: EN60601-1-2, FCC Class B, CE Class B, C-tick, IC, VCCI, NCC, TELEC, Wi-Fi Certified
System
• Wi-Fi Interface: 802.11b/g/n 2.4GHz 2x2 MIMO
• LAN Interface: 10/10/100 Gigabit Ethernet
• Antenna: 2x2 MIMO embedded antenna with 4 internal antennas
• Antenna Gain: 4.7 dBi
• Power Method: IEEE 802.3af Power Over Ethernet or external power adapter
Wireless Frequency
• 802.11b/g/n: 2.4GHz - 2.497GHz
Data Transfer Rate
• 802.11n:
6.5-130 Mbps (20MHz)
6.5-300 Mbps (40MHz)
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 Mbps
• 802.11b: 11, 5.5, 2 and 1 Mbps
The Output Power of Transmitter
• 802.11b:
21 dBm at 1, 2, 5.5, 11 Mbit/s
• 802.11g:
21 dBm at 6 Mbit/s~24 Mbit/s
19 dBm at 36 Mbit/s
18 dBm at 48 Mbit/s
17 dBm at 54 Mbit/s
• 802.11n (2.4GHz/HT-20)
20 dBm at MCS0/8
20 dBm at MCS1/9
20 dBm at MCS2/10
20 dBm at MCS3/11
19 dBm at MCS4/12
18 dBm at MCS5/13
17 dBm at MCS6/14
16 dBm at MCS7/15
• 802.11n (2.4GHz/HT-40)
19 dBm at MCS0/8
19 dBm at MCS1/9
19 dBm at MCS2/10
19 dBm at MCS3/11
17 dBm at MCS4/12
16 dBm at MCS5/13
14 dBm at MCS6/14
14 dBm at MCS7/15
Receiver Sensitivity
• 802.11b:
-89 dBm at 2 Mbit/s
-84 dBm at 11 Mbit/s
• 802.11g:
-85 dBm at 6 Mbit/s
-84 dBm at 9 Mbits/s
-84 dBm at 12 Mbit/s
-82 dBm at 18 Mbit/s
-78 dBm at 24 Mbit/s
-73 dBm at 36 Mbit/s
-70 dBm at 48 Mbit/s
-68 dBm at 54 Mbit/s
- 82dBm at MCS0/8
- 79dBm at MCS1/9
- 77dBm at MCS2/10
- 74dBm at MCS3/11
- 70dBm at MCS4/12
- 66dBm at MCS5/13
- 65dBm at MCS6/14
- 64dBm at MCS7/15
-79 dBm at MCS0/8
-76 dBm at MCS1/9
-74 dBm at MCS2/10
-71 dBm at MCS3/11
-67 dBm at MCS4/12
-63 dBm at MCS5/13
-62 dBm at MCS6/14
-61 dBm at MCS7/15
Security
• SSID: 16 SSID, Station Isolation
• Wireless Security:
WEP
Dynamic WEP
WPA Personal/Enterprise
WPA2 Personal/Enterprise
• Detection & Prevention: Rogue and Valid AP Classification
• Authentication:
MAC Address Filtering
802.1x
System Management
• Web-based User Interface: HTTP/HTTPS
• Command Line: SNMP, SSH, Telnet
Certificates
Order info
DWL-3600AP Unified N Access Point
Pictures
DWL-3600AP/Ax
Front view
Left side view
Back view
Downloads
Support Resources
