DCM-201EOL EOS
High-Speed Cable Modem
Where to buy
Description
The D-Link DCM-201 Cable Modem is a two-way DOCSIS 1.1 CableLabs compliant Ethernet 10/100Mbps Cable Modem enabling you to enjoy the benefits of a high-speed broadband Internet connection.The DCM-201 connects to your computer's Ethernet port or card via its Ethernet or USB port.The DCM-201 provides intelligent IP allocation management which can be configured to work on a Static or DHCP (Dynamic Host Configuration Protocol) network.For security,the DCM-201 provides 56-bit DES (Data Encryption Standard) to encrypt data transaction for both upstream and downstream transmission.
General features
Certificates
Order info
Pictures
DCM-201
Front view
Downloads
Support Resources
