Quick find
Product features:
Industrial Unmanaged Switch with 5 10/100Base-TX Ports
General features:
Hardware Version
• A1
Number of Ports
• 5 10/100Base-TX ports
Alarm Relay
• 1 A at 48 V
Diagnostic LEDs
• ALM
• P1/P2
• Link/Activity/Speed
Port Functions
• IEEE 802.3 for Ethernet
• IEEE 802.3u for Fast Ethernet
• IEEE 802.3x Flow Control
Media Interface Exchange
• Auto-MDI/MDIX adjustment for all twisted pair ports
Switching Capacity
• 1 Gbps
Transmission Method
• Store-and-forward
Maximum Forwarding Rate
• 0.744 Mpps
MAC Address Table Size
• Up to 1K entries
Advanced Features
• Broadcast/Multicast/Unicast Storm Control
• IEEE 802.1p Quality of Service (QoS) - 2 hardware queues per port
Physical Parameters
Power Input
• 12 to 58 V DC terminal block dual input
Power Consumption
• Maximum: 1.56 W
• Minimum: 0.95 W
Heat Dissipation
• 5.323 BTU/hr
MTBF
• > 25 years
Weight
• 0.32 kg
Dimensions
• 89.4 x 29.1 x 109.2 mm
Ventilation
• Fanless
Temperature
• Operating: -40° to 75°C
• Storage: -40° to 85°C
Humidity
• Operating: 5% to 95% non-condensing
• Storage: 5% to 95% non-condensing
Material
• IP30-rated metal casing
Installation
• DIN rail/wall mountable
Certifications
• UL/CE/FCC
Safety
• UL60950-1
EMI
• 47 CFR FCC Part 15 Subpart B (Class A)
• ICES-003 Issue 6 (Class A)
EMC
• EN61000-6-2
• EN61000-6-4
EMS
• EN 61000-4-2 ESD Level 3
• EN 61000-4-3 RS Level 3
• EN 61000-4-4 EFT Level 3
• EN 61000-4-5 Surge Level 3
• EN 61000-4-6 CS Level 3
• EN 61000-4-8
Environmental Tests
• IEC 60068-2-27 Shock
• IEC 60068-2-32 Freefall
• IEC 60068-2-6 Vibration
Products | Support  | News  | About |
