DEM-220R
Bi-directional SFP Transceiver for Fast Ethernet fiber optic cable (Tx: 1310nm, Rx: 1550)
Where to buy
Description
The DEM-220T/220R Bidirectional Fast Ethernet SFP Fiber Transceivers are external transceivers designed for insertion in SFP (Small Form-Factor Pluggable) slots of network devices for transmission and reception of data signals on the fiber cables. These transceivers provide the 100BASE-BX operation and physical compactness to deliver the speed, reliable long-distance data transfer, and deployment flexibility that today’s fiber networks require.
Ideal for Long Distance Application
The DEM-220T/220R transceivers can be used to connect together switches, servers and fiber modules on a campus or metropolitan area network (MAN). Providing up to 20 km of fiber cable distance, these highly integrated transceivers offer low jitter performance for extended optical link support without any degradation in performance.
Reliable Transmission
The DEM-220T/220R transceivers combine transmitting and receiving signals onto one fiber strand using two wavelengths. These transceivers are used in pair. At one end, one transceiver uses one wavelength to transmit and a second wavelength to receive. At the other end, the other transceiver flips that relationship.
Standard Compliance
The DEM-220T/220R transceivers use standard simplex LC connectors for fiber cable connection. They conform to industry standards and are interoperable with certain D-Link switches. Hot-swap capability allows network administrators to plug or unplug them from the SFP slots without having to turn off the power of the connected device.
Durable Design
The DEM-220T/220R transceivers are packed in a Small Form Pluggable (SFP) metal housing to increase durability.
General features
Standard:
IEEE 802.3ah 100BASE-BX
Wavelength:
Tx: 1310nm
RX: 1550nm
Connector:
Simplex LC connector
Fiber type:
9/125um Single-mode Fiber
Maximum Fiber Cable Length:
20km
Transmit Power Range:
-14 to -8dBm
Receive Power Range:
-32 to -3dBm
Sensitivity:
-32DBm
Power budget:
Minimum: 18dB
Maximum: 30dB
Power:
3.3V
Supply Current:
200mA
Heat Generated:
1.78kJ/h
MTBF (hours):
3,259,763
Dimensions:
55.5 x 13.4 x 28.11mm
Weight:
19.1g
EMI certifications:
FCC Class B
ICES-003 Class B
CE Class B
VCCI Class B
Security:
TUV
UL
FDA
Certificates
Order info
DEM-220R/10 Bi-directional SFP Transceiver for Fast Ethernet fiber optic cable (Tx: 1310nm, Rx: 1550)
Pictures
DEM-220R/C
Front view
View from the right
Downloads
Support Resources
