DPS-800Project
2-slot chassis
Description
	The DPS-800 chassis can hold two DPS-200, DPS-300 or DPS-500/500DC and is useful for adding a few RPS to the equipment rack.
	Using the chassis, users can save space, while their cabling will look neat. The chasses are not equipped with any power supply of their own. All redundant power supply units installed in the chassis will connect directly to their power source. As they are independent units, they are hot-swappable when used with the chassis.
General features
	Technical specifications
	2 slots chassis for DPS-200/300/500/500DC
Certificates
Order info
DPS-800 2-slot chassis
