חיפוש מהיר
תכונות המוצר:
נתב אלחוטי עם תמיכה ב 3G/LTE, עם 2 כניסות FXS, עם כניסה PSTN וכניסת USB
מאפיינים כללים:
Interfaces
• WAN port 10/100 / 1000BASE-T
• 4 LAN ports 10/100 / 1000BASE-T
• 2 FXS ports with RJ-11
• 1 PSTN port with RJ-11 (lifeline)
• USB 2.0 port
Indicators
• POWER
• ALARM
• REGISTER
• WLAN
• WAN
• 4 LAN indicator
• USB
• 2 indicators PHONE
• LINE
• WPS
Buttons
• ON / OFF button to power on / off
• RESET button to return to the factory default settings
• WPS button to establish a secure wireless connection and enable / disable the wireless network
Antenna
• Two non-removable external antenna with 5 dBi gain
Scheme MIMO
• 2 x 2
Power connector
• Power connector (DC)
SIP functions
• Individual account for each port
• Call without registration
• Register for the IP-address or domain name of SIP-server
• Redundant SIP proxy server
• Support for DHCP-options 120
• Support the format of SIP URI (RFC3986)
• Support for the outgoing (outbound) proxy
• STUN-client
• Supports NAT (NAT keep-alive)
• Types of calls: Voice / Modem / Fax
• User-configurable dialing plan (dial plan)
• Identify the source and destination call manually (P2P)
• Dialing E.164 (Rule exceptions ENUM)
Call Functions
• Direct call IP-to-IP without SIP proxy
• Life-Line (PSTN-backup)
• Yield to PSTN prefix
• Hold / Resume call
• Call Waiting
• Forwarding (unconditional, if busy, if no answer)
• "Do not disturb"
• Speed ​​Dial
• Phone book
• "Hot line
• Shortcuts to special functions
• Intercom (internal calls without using the server SIP)
Voice Features
• Codecs: G.711 a / μ-law, G.729A, G.726, G.722, G.723.1
• Detection and generation of DTMF
• In-band DTMF, out-of-band DTMF (RFC2833, SIP-INFO)
• Comfort Noise Generation (CNG)
• Voice Activity Detection (VAD)
• Dynamic jitter-buffer
• Generation of call progress signal (FXS)
• Support for tone / pulse dialing
• Detection and generation Caller ID (Caller ID)
• Support fax (T.30 FAX bypass for G.711, T.38 Real Time FAX Relay)
• Adjustable Flash Time
• Adjusting the volume (speaker / microphone)
WAN connection types
• LTE
• 3G
• PPPoE
• Static IP / Dynamic IP
• PPPoE + Static IP
• PPPoE + Dynamic IP
Network Features
• DHCP-server / relay
• DNS relay
• Dynamic DNS
• IGMP Proxy
• RIP
• Support UPnP IGD
• VLAN support
• Supports ping from external network (WAN ping respond)
• Support SIP
• Support for RTSP
Firewall Security
• Stateful Inspection (SPI)
• IP-filter
• MAC-Filter
• URL-filter
• The protection ARP- and DDoS-attacks
• Virtual Servers
VPN
• IPSec / PPTP / L2TP / PPPoE pass-through
USB-interface features
• USB-modem
• Automatic connection to available type of supported network (4G / 3G / 2G) 1
• Enable / Disable checking PIN-code change PIN-koda2
• USB-drive
• File Browser
• Print Server
• Accounts to access the drive
• Built-in Samba server
• Built-in FTP-server
• Built-in torrent-client Transmission, the ability to download files to a USB-drive with him
Control
• Local and remote access to the settings of TELNET / WEB (HTTP)
• Web-based interface for configuration and management of multiple languages
• Update the router via web-interface
• Automatic notification of a new software version
• Saving and loading configurations
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually configure the date and time
• Ping
• Traceroute
• TR-069 Client
Wireless module
• IEEE 802.11b / g / n
Frequency Range
• 2400 ~ 2483.5 MHz
Wireless Security
• WEP
• WPA / WPA2 (Personal / Enterprise)
• MAC filter
• WPS (PBC / PIN)
Additional functions
• WMM (Wi-Fi QoS)
• Control connected devices
• Advanced settings
Wireless speed
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11n (2,4 GHz) of 6.5 to 300 Mbit / s (MCS0 to MCS15)
Transmitter output power
The maximum transmit power will vary according to the rules of radio frequency regulation in your country
• 802.11b (typically at room temperature, 25 ° C)
15 dBm at 1, 2, 5.5 and 11 Mbit / s
• 802.11g (typically at room temperature, 25 ° C)
15 dBm at 6, 9, 12, 18, 24, 36, 48, 54 Mbit / s
• 802.11n (typically at room temperature, 25 ° C)
HT20 / HT40
15 dBm at 15 MCS0 ~
Receiver Sensitivity
• 802.11b (typically at PER = 8% at room temperature, 25 ° C)
-85 DBm at 1 Mbit / s
-83 DBm at 2 Mbit / s
-81 DBm at 5.5 Mbit / s
-79 DBm at 11 Mbit / s
• 802.11g (typically at PER = 10% at room temperature, 25 ° C)
-85 DBm at 6 Mbit / c
-84 DBm at 9 Mbit / c
-82 DBm at 12 Mbit / c
-80 DBm at 18 Mbit / c
-77 DBm at 24 Mbit / c
-73 DBm at 36 Mbit / c
-69 DBm at 48 Mbit / c
-68 DBm at 54 Mbit / c
• 802.11n (typically at PER = 10% at room temperature, 25 ° C)
2.4 GHz, HT20
-85 DBm at MCS0 / 8
-82 DBm at MCS1 / 9
-80 DBm at MCS2 / 10
-77 DBm at MCS3 / 11
MCS4 at -73 dBm / 12
-69 DBm at MCS5 / 13
-68 DBm at MCS6 / 14
-67 DBm at MCS7 / 15
2.4 GHz, HT40
-82 DBm at MCS0 / 8
-79 DBm at MCS1 / 9
-77 DBm at MCS2 / 10
-74 DBm at MCS3 / 11
MCS4 at -70 dBm / 12
-66 DBm at MCS5 / 13
-65 DBm at MCS6 / 14
-64 DBm at MCS7 / 15
Modulation Schemes
• 802.11g: BPSK, QPSK, 16QAM, 64QAM OFDM-
• 802.11n: BPSK, QPSK, 16QAM, 64QAM OFDM-
נתונים פיזיים
Size
• 224 x 171 x 50 mm
Weight
• 480 g
Power
• Output: 12V DC, 1.5A
Temperature
• Operating: 0 to 40 ° C
• Storage: -20 to 65 ° C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Supported USB-modems
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E352 (Megafon)
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
CDMA
• Airplus MCD-650
• Airplus MCD-800
• AnyDATA ADU-300A
• AnyDATA ADU-500A
• AnyDATA ADU-510A
• Huawei EC306
• ZTE AC5710
• ZTE AC5730
LTE
• Huawei E3372
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-2
• Megafon M150-2
• Yota LU-150
• Yota WLTUBA-107
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
