חיפוש מהיר
תכונות המוצר:
נתב אלחוטי דואל-בנד בתקן AC-1200 עם 4 יציאות גיגהביט ויציאת USB להתקנים שונים
דגם לא מיוצר יותר
מאפיינים כללים:
Interfaces
• WAN port 10/100 / 1000BASE-TX
• 4-port LAN 10/100 / 1000BASE-TX
• USB 2.0 port
Indicators
• POWER
• STATUS
• WAN
• 4 LAN indicator
• WLAN
Button
• ON / OFF button to power on / off
• RESET button to return to the factory default settings
• WPS button to establish a secure wireless connection and enable / disable the wireless network
Antenna
• Two non-removable external antenna with a gain of 2 dBi for 2.4 GHz and 3 dBi for 5 GHz
Power connector
• Connector for power supply (DC)
WAN connection types
• LTE
• 3G
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IP / Dynamic IP
• Static IPv6 / IPv6 Dynamic
• PPPoE + Static IP
• PPPoE + Dynamic IP
• PPTP / L2TP + Static IP
• PPTP / L2TP + Dynamic IP
Network Functions
• Supports IEEE 802.1X standard for connecting to the Internet
• DHCP-server / relay
• DHCPv6-server (Stateful / Stateless), IPv6 prefix delegation
• DNS relay
• Support Class AAAA records DNSv6
• Dynamic DNS
• Static IP-routing
• Static IPv6-routing
• IGMP Proxy
• RIP
• Supports UPnP IGD
• VLAN support
• Flow control (flow control)
• Supports ping from the external network (WAN ping respond)
• Support for SIP
• Support for RTSP
Firewall Features
• IP-filters
• IPv6-filters
• MAC-filter
• URL-filter
• DMZ-zone
• The protection ARP- and DDoS-attacks
• Virtual Servers
• Built-in content filtering service Yandeks.DNS
VPN
• IPSec / PPTP / L2TP / PPPoE pass-through
• VPN-tunnels (PPPoE, PPTP, L2TP)
• IPSec-tunnel
Function USB-interface
• USB-modem
   Automatic connection to available type of supported network (4G / 3G / 2G) 2
   Enable / disable PIN-code verification, change PIN-koda3
• USB-drive
   Print Server
   Built-in Samba server
   Built-in FTP-server
   Built-in DLNA-server
   Built-torrent-client Transmission, the possibility of downloading files on USB-drive with him
Management
• Local and remote access to the settings on the TELNET / WEB (HTTP / HTTPS)
• Web-based interface for configuration and management of multiple languages
• Notification of problems with connection and automatic redirection settings
• Update the router through the web-interface
• Automatic notification when a new software version
• Saving and loading configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually configure the date and time
• Ping
• Traceroute
• Client TR-069
נתונים פיזיים
• Dimensions 195 x 155 x 35 mm
• Weight 250 g
• Power Output: 12 V DC, 1.5 A
Temperature
• Operating: 0 to 40 ° C
• Storage: -20 to 65 ° C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Supported USB-modems
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E352 (Megafon)
• Huawei E367 (3G-mode)
• Huawei E392 (3G-mode)
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
CDMA
• Airplus MCD-650
• Airplus MCD-800
• AnyDATA ADU-300A
• AnyDATA ADU-500A
• AnyDATA ADU-510A
• Huawei EC306
• ZTE AC5710
• ZTE AC5730
LTE
• Huawei E3131
• Huawei E3272
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-3
• Megafon M100-4
• Megafon M150-1
• Yota LU-150
• Yota WLTUBA-107
• ZTE MF823
• ZTE MF827
• MTS 824F
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
