DVG-N5402SP/2S1U/C1A
נתב אלחוטי בתקן 802.11n עם שתי כניסות FXS ו-4 כניסות LAN + פורט USB
היכן לקנות
תאור
SIP-telephony
VoIP- Router is equipped with two FXS- ports that allow you to connect analog phones to make calls over the Internet.
USB-port
The router is equipped with USB- port for connecting a USB- modem with which you can quickly connect to the Internet . In addition , you can connect to the USB- port on the router USB- drive, which will be used as a network drive , or a printer.
Wireless Interface
Using Wireless Router DVG-N5402SP, you can quickly arrange high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices almost anywhere (within range of a wireless network.) The Router can serve as an access point to connect to the wireless network devices of the standards 802.11b, 802.11g and 802.11n ( up to 300 Mbit / s) . Enable and disable the wireless network router , you can single click WLAN, located on the device .
In the router supports multiple functions for the wireless interface . The device supports several security standards (WEP, WPA/WPA2), filtering devices to be connected to MAC- address , as well as allows you to use WPS, WMM.
Security
Wireless Router DVG-N5402SP provides firewall . Enhanced security functions minimize threats of hackers and prevent intrusions to your network .
Configuration and Management
To manage and configure the wireless router DVG-N5402SP uses a simple and user-friendly web- interface ( available in several languages ​​) .
מאפיינים כללים
WAN interface
• 1 10/100BASE-TX Ethernet port for cable or DSL- modem or connect to a dedicated Ethernet- line
LAN interface
• 4-port 10/100BASE-TX Ethernet
WLAN interface
• IEEE 802.11n ( up to 300 Mbit / s)
• IEEE 802.11b / g
FXS interface
• 2 FXS ports for connecting analog telephone or fax machine
USB interface
• USB 2.0 type A to USB- modem connection , drive or printer
Frequency band
• 802.11b
  ◦ 2400 ~ 2484 MHz ISM band
• 802.11g
• 802.11n
  ◦ HT20: 2400 ~ 2483.5 MHz ISM band
  ◦ HT40: 2422 ~ 2452 MHz ISM band
Speed ​​Wireless
• 802.11b
  ◦ 11, 5.5, 2 and 1 Mbit / c for each channel, with automatic speed
• 802.11g
  ◦ 54, 48, 36, 24 , 18, 12 , 9 and 6 Mbit / s for each channel, with automatic speed
• 802.11n
  ◦ HT20: up to 150 Mbit / s
  ◦ HT40: up to 300 Mbit / s
Modulation Schemes
• 802.11b: CCK, DQPSK, DBPSK
• 802.11g: 64QAM, 16QAM, QPSK, BPSK, DSSS
• 802.11n: 64 QAM, 16QAM, QPSK, BPSK
Basic functions SIP
• Individual account for each port
• Invite with Challenge
• Register for IP-address SIP- server or domain name
• Support the format of SIP URI (RFC3986)
• Support for outbound (outbound) proxy
• Timers sessions (update / re-invite)
• Support for DNS SRV
• Types of calls: Voice / Modem / Fax
• User-configurable dial plan (dial plan)
• Identify the source and destination (P2P- calls) manually
• Dialing E.164 ( with an exclusion rule ENUM)
Call functions
• Direct call IP-to-IP without SIP proxy
• Hold / resume a call
• Call Waiting
• Forwarding (unconditional , on busy , no answer )
• " Do not disturb"
• Message Waiting Indication (MWI)
• Lock Hidden Numbers
• AntiAON
• Speed ​​Dial
• "hotline"
Voice features
• Codecs : G.711 a / μ-law, G.729A, G.726, G.722
• DTMF detection and generation
• Comfort noise generation (CNG)
• Voice Activity Detection (VAD)
• Variable (dynamic ) jitter- buffer
• Generation of call progress tone (FXS)
• Program Gain
• In-band DTMF, out-of-band DTMF (RFC2833, SIP-INFO)
• Support for tone / pulse dialing
• Detection and generation Caller ID (Caller ID)
• T.30 FAX bypass to G.711, T.38 Real Time FAX Relay
Network features
• Types of WAN- connections:
  ◦ 3G
  ◦ PPPoE
  ◦ Static IP
  ◦ Dynamic IP
  ◦ PPTP/L2TP
  ◦ PPTP/L2TP + Static IP
  ◦ PPTP/L2TP + Dynamic IP
• DHCP- Server and DHCP- Client
• DNS relay
• Skip VPN- tunnel (PPTP/L2TP)
• Dynamic DNS
• Static IP- routing
• Remote access
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• VLAN support
• Supports ping from the external network (WAN ping respond)
USB-modem *
• Automatically connect to an available type of supported network (3G/2G)
• Enable / disable PIN- code verification , change PIN- code
USB-drive
• Access via SMB
• Built-in FTP- server
• Print Server
• Accounts for access to the drive
Wireless connection
• Supported safety standards :
  ◦ WEP
  ◦ WPA/WPA2 Personal
  ◦ WPA/WPA2 Enterprise
• MAC- filter
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
• Advanced Settings
Torrent-client
• Ability to download files on the USB- drive and a Firewall Functions
• IP- filters
• MAC- filter
• URL- Filter
• DMZ- zone
• Protection and ARP- DDoS-attacks
• Virtual servers
• Web- based interface for configuration and management of multiple languages
• Access via TELNET
• Upgrade the firmware of the router through the web- interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP- server and manually configure the date and time
• Ping
• traceroute utility
Supported USB- modems *
• GSM- modems
  ◦ D-Link DWM- 152
  ◦ D-Link DWM- 156
  ◦ Huawei E160G
  ◦ Huawei E169G
  ◦ Huawei E171
  ◦ Huawei E220
  ◦ ZTE MF112
  ◦ ZTE MF192
  ◦ ZTE MF626
  ◦ ZTE MF627
  ◦ ZTE MF652
  ◦ ZTE MF668
  ◦ ZTE MF752
• CDMA- modems
  ◦ Airplus MCD- 650
  ◦ Airplus MCD- 800
  ◦ AnyDATA ADU-300A
  ◦ AnyDATA ADU-500A
  ◦ AnyDATA ADU-510A
  ◦ ZTE AC5710
  ◦ ZTE AC5730
נתונים פיזיים
Indicators
• POWER
• WAN
• 4 LEDs LAN
• WLAN
• WPS
• USB
• Indicator 2 FXS
Power
• Power supply: External Power Adapter DC 12V/1.25A
• Power on / off
• RESET button to return to the factory defaults
• WPS button
• Power on / off the wireless network
Operating temperature
• From 0 to 40 C
Storage temperature
• -20 To 70 ° C
Operating humidity
• From 10% to 90% non-condensing
Storage humidity
• From 5% to 95% non-condensing
תקנים
הורדות
איורים
DVG-N5402SP/2S1U/C1A/2S1U/C1
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
