DPR-1020EOL EOS
שרת הדפסה קווי עם כניסת USB
היכן לקנות
תאור
SHARE YOUR PRINTER AND MULTIFUNCTION EQUIPMENT
The DPR-1020 USB Multifunction Print Server provides users with the ability to share their printer on a network and offers print and scan compatibility for those who are using multifunction equipment. This print server allows multiple users to directly send out documents from their PC for printing and fax transmissions. Share your printer and multifunction equipment's printing, faxing, and scanning functions with the users on your network - all from a single stylish and compact device.
OPERATE ALL DEVICES SIMULTANEOUSLY
Equipped with a powerful CPU, large memory, high speed USB 2.0 port and capable of up to 100Mbps network data transfer, this print server makes your operations fast and effi cient. Printers attached to the DPR-1020 can print, scan, and fax at the same time, giving this device better performance than any software-based print server at a fraction of the cost.
ACCESS SECURITY AND MULTIPLE OS SUPPORT
The DPR-1020 provides all the necessary security you need by allowing the administrator to confi gure user access rights to the printer. It supports a wide range of network operating systems including: Windows NT/2000/XP/Vista, Apple MacOS with AppleTalk, Linux, and Unix. Administrators will appreciate the fl exibility and compatibility that this print server offers.
SUPPORT FOR REMOTE PRINTING
The DPR-1020 supports the Internet Printing Protocol (IPP), enabling remote users to output fi les to their offi ce printer even when they are away from the office. The device also provides network administrators with critical information about the network printer so they can monitor printer operations in a timely manner. With the DPR-1020, you will never again have to worry about printing out important fi les where ever you are
מאפיינים כללים
תקנים
  • IEEE 802.3
  • IEEE 802.3u
  • USB 2.0
פורטים
  • 1 פורט USB
  • 1 פורט 10/100Base-TX Ethernet LAN
ניהול
  • ניהול מתבצע דרך דפדפן אינטרנט
  • שרת DHCP ולקוח
  • תוכנה לניהול וגישה לשרת דפוס
תמיכה במערכות הפעלה
  • Windows Vista/XP/2000/NT4/ME
  • Apple Mac OS 9.x to Mac OS X 10.4.x
  • Linux
נתונים פיזיים
חמשל
  • 5V-2.5A
משקל
  • 77 גרם
מידות
  • 67X25X106 מ"מ
תקנים
הורדות
איורים
DPR-1020
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
