חיפוש מהיר
תכונות המוצר:
דגם לא מיוצר יותר
מאפיינים כללים:
             Specifications:
             Available functions
·         Placement of up to 50 user accounts in the internal  database
·         Support for 5 concurrent calls
·         Authentication and authorization based on the ID / Пароле
·         Support for internal authentication mechanism
·         Access to the WEB-Interface
·         Remote access to the command line interface for SSH
·         Static IP, DHCP-client interfaces
·         Supported VoIP Codecs G.711 (μlaw, alaw)
Hardware Platform
·         Processor
·         Intel IHP-425 or 266 MHz Intel IXP-425 533 MHz
Memory
·         64 MB SDRAM
·         16 MB Flash
Ports device
·         7 10/100Mbit/s Fast Ethernet
·         4 independently configurable interfaces (can be used as a LAN, WAN, the issuance of port statistics)
Indicators
·         Power (Power)
·         Status (Status)
·         7 indicators port Fast Ethernet
Physical parameters
Nutrition through an external power adapter
·         The voltage at the input
5V/3A DC
Size
·         239 x 156 x 30 mm
Weight
·         1,2 kg
·         Steel Case
·         Operating temperature 0 ° to 45 ° C
·         Storage temperature -25 ° to 55 ° C
·         Humidity 10% to 95% without condensation
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
