חיפוש מהיר
תכונות המוצר:
טלפון VOIP עם תמיכה ב SIP וב PoE עם פורט 1 LAN ועם פורט 1 WAN
מאפיינים כללים:
Network Interfaces
• 1 port WAN 10/100BASE-TX PoE support for Internet connectivity
• 1 LAN 10/100BASE-TX port for connection to PC
Signaling, media and network protocols
• SIP RFC 3261
• SIP RFC 2327
• RTP RFC 1889
• Assign IP-address: Static IP-address, DHCP and PPPoE
• STUN, static port mapping (for NAT traversal)
• SNTP
• DNS and DNS SRV
• TFTP / FTP / HTTP / HTTPS for Auto Provision
• IP / TCP / UDP / ARP / ICMP
• Router and Bridge
Audio Codecs
• G.711a / u (64 kbit / s)
• G.729A / B (8 kbit / s)
• G.723.1
• G.722
• G.726-32
Advanced features
• Silence Suppression
• Acoustic echo cancellation (G.167)
• Voice Activity Detection (VAD)
• Comfort noise generation
• Jitter-buffer
• Transmitter DTFM (SIP info, Transparent, RFC 2833)
• Packet Lost Concealment (PLC)
Keyboard
• 4 soft keys to perform certain functions
• 5 keys SIP line
• MWI
• Headphones
• RLS (Release Key)
• Call Hold (Hold)
• Call forwarding (Transfer)
• Conference (CONF)
• Phonebook
• Call History (History)
• Redial (Redial and write access to the file of calls, with completion set and call numbers)
• Speaker (Speaker)
• 4 arrow keys to navigate through the settings, setting the level of the ringer, speaker and handset
• Enter (confirm button)
• 12 numeric keys, including the * and # keys
• Mute (Mute)
• Volume control (Vol-/Vol +)
Phone Functions
• Multiple users (5 accounts SIP)
• Automatic Caller ID
• Archive of calls: 100 missed calls, 100 incoming calls, outgoing calls 100
• Phone book (up to 500 contact names and phone numbers)
• Remote phone book (up to 4 phone books in the format xml)
• Date / Time
• Display call timer
• 11 call tones to choose from (9 call tones and 3 tones)
• 9 speed dial
• The incoming call
• Flexible dial map
• Password protection for access to the configuration interface
• Pre-dial before sending
• Connectivity Expansion Module Keys
• MWI
• SMS
• Key lock
• Emergency call
Function calls
• Call Hold Resume
• Muting
• Call transfer (accompanied or unaccompanied)
• Call forwarding (busy, no answer, of course)
• Call Waiting
• Call waiting indication
• Three-way conference
• Anonymous call / Reject
• Message waiting indication
• "Do not disturb"
• Auto Answer
• Black List
• Limit List
• Auto hangup
• Automatic Dialing
• Prohibition of certain outgoing calls
• «hot line»
• BLF / Presence
• Intercom
• Call Pickup (Call Pickup)
• Action url / Active uri
Network functions
• QOS: IEEE 802.1p and IEEE 802.1Q
• Diffserv (DSCP) / ToS
• Support for a full range of VLAN ID
• Class of Service Support by VLAN Tag
• LLDP
• L2TP VPN / OpenVPN
User interface / network management
• The user interface screen / keyboard in English and other languages
• Web-user interface (HTTP) in English and other languages
• Remote software upgrade via FTP / TFTP / HTTP
• APS auto-provisionning for software update and profile
• Appearance update firmware in case of damage
נתונים פיזיים
Input Power
• 100 ~ 120, 220 ~ 240V AC power via an external power adapter
Output Power
• 5 VDC, 1A
Power consumption
• Typical: 2.5 W (Standby)
• Max.: 2.8 W (during a call)
Measurements
• 240 x 185 x 45 mm
Weight
• 0.99 kg
Operating temperature
• 0 ° to 40 ° C
Storage temperature
• -20 ° to 60 ° C
Operating humidity
• From 10 to 65% non-condensing
Storage humidity
• From 15 to 85% non-condensing
Certificates
• CE Class B
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
