חיפוש מהיר
תכונות המוצר:
נתב אלחוטי בתקן 802.11n עם שתי כניסות FXS, כניסת WAN ו-4 כניסות LAN + פורט USB
תאור:
Internet Phone Solution for Home & SOHO
The D-Link DVG-N5402SP Wireless N VoIP Router allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over IP network technology with advanced communication features, and is compatible with phone services industry-wide. This VoIP Router connects you to up to two ordinary phone sets for phone calls, allowing you to make two separate calls simultaneously.
Superior voice quality
The DVG-N5402SP incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that of ordinary phones. It supports many useful functions like call transfer, caller ID display, 3-way conferencing, a phone book, speed dialing and hotlines to make it convenient to dial out or answer phone calls.
Complete security
The DVG-N5402SP supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides a lifeline phone port to relay your incoming and outgoing phone calls to PSTN for in case a network outage occurs. This guarantees that your phone connection will always be available.
Integrated wireless 4-port router
The DVG-N5402SP provides an 802.11n standard wireless LAN and router function with a built-in NAT/DHCP server to permit multiple computers to share an Internet broadband connection. Connect your wireless devices with high-speed 802.11n wireless networking. Also, with four integrated Switch Ethernet ports, four Ethernet-enabled computers and network devices can connect to the Internet.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
