DGE-530T
כרטיס רשת GigaExpress PCI 10/100/1000Mbps
היכן לקנות
תאור
Main Features
  • 32bit PCI BUS Master
  • PCI 2.2 Plug-and-Play Support
  • Auto-negotiating 10/100/1000Mbps
Product Description
The D-Link DGE-530T is a 10/100/1000Mbps copper Gigabit PCI card for servers and workstations.
Current systems running at 10Mbps and 100Mbps can be upgraded to Gigabit Ethernet, eliminating network bottlenecks, and increasing productivity. Integrate Gigabit now and you can save time, money, and downtime because the DGE-530T will automatically detect and run at higher speeds when it becomes available.
Cost-Effective, Scalable Migration
As an inexpensive alternative solution to fiber-optic, the card allows you to instantly upgrade to Gigabit without requiring you to install new, expensive fiber cables. Gigabit Ethernet uses your existing Category-5 cabling while providing you with 10/100/1000Mbps network speed auto-sensing and full/half duplex auto-negotiation.
Advanced Features and Security
The DGE-530T supports SNMP for remote troubleshooting and management, ACPI for lower power consumption, and WoL for remote wake. This helps to lower total cost of ownership (TCO). The card also features on-board screening of VLAN Tagged Ethernet frames, allowing you to assign multiple subnets to each server and isolate devices within each VLAN from the rest of the network for better traffic control and security. It also supports 802.1p Priority Tagging to allow you to prioritize traffic. The card also features embedded flow control and independent FIFO, providing a means to protect against possible data loss during transmission on the network. With the Cable Diagnostic feature, the card will automatically detect whether you have a bad cable, making your troubleshooting task easier.
מאפיינים כללים
Technical Specifications
Standards
IEEE 802.3 10Base-T Ethernet
IEEE 802.3u 100Base-TX Fast Ethernet
IEEE 802.3ab 1000Base-T Gigabit Ethernet
IEEE 802.3x Flow Control
ANSI/IEEE 802.3 Nway Auto-Negotiation
IEEE 802.1p Priority Tagging
IEEE 802.1q VLANs
Features
PCI Local Bus Master 2.1/2.2 Support
Plug-and-Play Installation
Supports PCI 2.1/2.2 ACPI Power Management Wake-On-LAN
Compliant to PC 99 Standard (Magic Packet, LinkChg and Microsoft wake-up frame)
Independent 2Kb Receive and Transmit FIFOs
Advanced Cable Diagnostics (Windows Utility)
Jumbo Frame Support
Network Data Transfer Rate
Ethernet: 10Mbps (Half-duplex)
Ethernet: 20Mbps (Full-duplex)
Fast Ethernet: 100Mbps (Half-duplex)
Fast Ethernet: 200Mbps (Full-duplex)
Gigabit Ethernet: 1000Mbps (Half-duplex)
Gigabit Ethernet: 2000Mbps (Full-duplex)
Drivers Supported
Windows Server 2003
Novell Netware 5.x, 6.x ODI driver
Windows XP
FTP PC/TCP
Linux Kernal 2.6.5
MAC OS 10.2x
Protocol
CSMA/CD
Network Media
Ethernet: UTP Cat3, 4, 5 EIA/TIA-568 100-ohm screened twisted-pair (STP)
Fast Ethernet: UTP Cat5, EIA/TIA-568 100-ohm screened twisted-pair (STP)
Network Management
SNMPv1
Led
Link
Activity
Certifications
FCC Class B
Operating Temperature
32°F to 104ºF (0°C to 40°C)
Operating Humidity
5% to 90% Maximum (Non-condensing)
Dimensions
Item (WxDxH): 1.97” x 4.72” x 0.08”
Packaging (WxDxH): 6.69” x 9.5” x 1.5”
Weight
Item: 0.1 lbs
Packaging: 0.4 lbs
Warranty
1-Year*
Minimum System Requirements
Computer with:
Windows Vista™, Windows® XP SP2, Windows 2000 SP4** or Mac OS® X (v10.2/v10.3)***
CD-ROM Drive
20MB Hard Disk Space
32-Bit PCI Slot
Package Contents
10/100/1000 Gigabit Desktop PCI Adapter
Standard & Low Profile Mounting Brackets
Quick Installation Guide
CD-ROM**** with:
Installation Wizard
Product Documentation
נתונים פיזיים
תקנים
הורדות
איורים
DGE-530T
מראה מקדימה
מראה מקדימה
דף מידע
ראה גם
