DGE-530TEOL
כרטיס רשת GigaExpress PCI 10/100/1000Mbps
תאור
Main Features
  • 32bit PCI BUS Master
  • PCI 2.2 Plug-and-Play Support
  • Auto-negotiating 10/100/1000Mbps
Product Description
The D-Link DGE-530T is a 10/100/1000Mbps copper Gigabit PCI card for servers and workstations.
Current systems running at 10Mbps and 100Mbps can be upgraded to Gigabit Ethernet, eliminating network bottlenecks, and increasing productivity. Integrate Gigabit now and you can save time, money, and downtime because the DGE-530T will automatically detect and run at higher speeds when it becomes available.
Cost-Effective, Scalable Migration
As an inexpensive alternative solution to fiber-optic, the card allows you to instantly upgrade to Gigabit without requiring you to install new, expensive fiber cables. Gigabit Ethernet uses your existing Category-5 cabling while providing you with 10/100/1000Mbps network speed auto-sensing and full/half duplex auto-negotiation.
Advanced Features and Security
The DGE-530T supports SNMP for remote troubleshooting and management, ACPI for lower power consumption, and WoL for remote wake. This helps to lower total cost of ownership (TCO). The card also features on-board screening of VLAN Tagged Ethernet frames, allowing you to assign multiple subnets to each server and isolate devices within each VLAN from the rest of the network for better traffic control and security. It also supports 802.1p Priority Tagging to allow you to prioritize traffic. The card also features embedded flow control and independent FIFO, providing a means to protect against possible data loss during transmission on the network. With the Cable Diagnostic feature, the card will automatically detect whether you have a bad cable, making your troubleshooting task easier.
מאפיינים כללים
Technical Specifications
Standards
• IEEE 802.3 10Base-T Ethernet
• IEEE 802.3u 100Base-TX Fast Ethernet
• IEEE 802.3ab 1000Base-T Gigabit Ethernet
• IEEE 802.3x Flow Control
• ANSI/IEEE 802.3 Nway Auto-Negotiation
• IEEE 802.1p Priority Tagging
• IEEE 802.1q VLANs
Features
• PCI Local Bus Master 2.1/2.2 Support
• Plug-and-Play Installation
• Supports PCI 2.1/2.2 ACPI Power Management Wake-On-LAN
• Compliant to PC 99 Standard (Magic Packet, LinkChg and Microsoft wake-up frame)
• Independent 2Kb Receive and Transmit FIFOs
• Advanced Cable Diagnostics (Windows Utility)
• Jumbo Frame Support
Network Data Transfer Rate
• Ethernet: 10Mbps (Half-duplex)
• Ethernet: 20Mbps (Full-duplex)
• Fast Ethernet: 100Mbps (Half-duplex)
• Fast Ethernet: 200Mbps (Full-duplex)
• Gigabit Ethernet: 1000Mbps (Half-duplex)
• Gigabit Ethernet: 2000Mbps (Full-duplex)
Drivers Supported
• Windows Server 2003
• Novell Netware 5.x, 6.x ODI driver
• Windows XP
• FTP PC/TCP
• Linux Kernal 2.6.5
• MAC OS 10.2x
Protocol
• CSMA/CD
Network Media
• Ethernet: UTP Cat3, 4, 5 EIA/TIA-568 100-ohm screened twisted-pair (STP)
• Fast Ethernet: UTP Cat5, EIA/TIA-568 100-ohm screened twisted-pair (STP)
Network Management
• SNMPv1
Led
• Link
• Activity
Certifications
• FCC Class B
Operating Temperature
• 32°F to 104ºF (0°C to 40°C)
Operating Humidity
• 5% to 90% Maximum (Non-condensing)
Dimensions
• Item (WxDxH): 1.97” x 4.72” x 0.08”
• Packaging (WxDxH): 6.69” x 9.5” x 1.5”
Weight
• Item: 0.1 lbs
• Packaging: 0.4 lbs
Warranty
• 1-Year*
Minimum System Requirements
• Computer with:
• Windows Vista™, Windows® XP SP2, Windows 2000 SP4** or Mac OS® X (v10.2/v10.3)***
• CD-ROM Drive
• 20MB Hard Disk Space
• 32-Bit PCI Slot
Package Contents
10/100/1000 Gigabit Desktop PCI Adapter
Standard & Low Profile Mounting Brackets
Quick Installation Guide
CD-ROM**** with:
Installation Wizard
Product Documentation
תקנים
הורדות
איורים
DGE-530T/D
מראה מקדימה
מראה מקדימה
דף מידע
ראה גם
