חיפוש מהיר
תכונות המוצר:
מתאם רשת אלחוטי PCI express בתקן 802.11N עד 300Mbps
תאור:
The increased speed and extended range of the network
Wireless Adapter PCI Express Wireless N 300 DWA-548 allows you to connect to high-speed wireless network. Extended range and increased speed ensures fast and reliable connection anywhere in your home.
Advantages of PCI Express
PCI Express technology provide high throughput, increased performance and allows you to connect the adapter DWA-548 to any PCIe slot machine - x1, x4, x8, or x16.
Connecting to a network
This adapter is based on Wireless N technology delivers high performance wireless network. DWA-548 is designed for use in bigger homes and for users who require high speed data transmission for the network. The adapter can be connected to the wireless Wireless N router from anywhere in the house. Also, DWA-548 is backward compatible with 802.11g and 802.11b and supports encryption of WPA and WPA2, which provides wireless security.
Easy to install and use
Quick Setup Wizard provides step by step instructions for getting this adapter without the help of a specialist. The package includes a utility for managing your wireless connections (Wireless Manager), which allows you to keep track of the most frequently accessed networks. With its high performance, excellent reception and enhanced security, this adapter is the perfect choice to create or improve connectivity to the desktop wireless network.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
