DFL-210EOL EOS
פיירוול UTM (כולל AV, WCF) לאבטחה מושלמת לרשת הארגונית - 4 יציאות LAN, יציאת WAN, יציאת DMZ - עד 80Mbps
תאור
Main Features
   * 4 x LAN, 1 x WAN, 1 x DMZ ports
   * Firewall Throughput: 80Mbps
   * VPN Throughput: 25Mbps
   * Concurrent sessions: 12,000
   * Policeis: 500
   * Dedicated VPN Tunnels: 100
The NetDefend family of Firewall/VPN Security Appliances is D-Link’s answer for hardware-based network security. The new D-Link Network Security Firewall (DFL-210) is an easy-to-deploy VPN and firewall solution designed specifically for the Small Office / Home Office (SOHO) market that demands superior performance and security.
Advanced Hardware Features
The DFL-210 is a powerful security solution that provides integrated Network Address Translation (NAT), SPI Firewall, advanced content filtering features, IDS protection, bandwidth management, as well as Virtual Private Network (VPN) support. The DFL-210 hardware includes four trusted LAN ports, a WAN port, and a user-configurable DMZ port to support local servers such as e-mail, Web, and FTP. The DMZ port can also be reconfigured as a WAN fail-over port. All of these features conveniently fit into a desktop chassis that can be easily integrated into your network.
Enterprise-class Security
To provide enterprise-class network security, the DFL-210 has several flexible firewall features to manage, monitor, and maintain a healthy and secure network. Network management features include: Remote Management, Bandwidth Control Policies, URL/Keyword Blocking, Access Policies, and SNMP. For network monitoring, the DFL-210 supports e-mail alerts, system log, consistency checks, and real-time statistics. These features along with a firmware backup function provide and maintain maximum network performance and security.
VPN Performance
For optimal VPN configuration, the DFL-210 has an integrated VPN Client and Server to support almost any required VPN policy. This high-end appliance has a hardware VPN engine to support and manage up to 100 VPN configurations. The DFL-210 can support IPSec, PPTP, and L2TP protocols in Client/Server mode and can handle pass-through traffic as well. Advanced VPN configuration options include: DES/3DES/AES/Twofish/Blowfish/CAST-128 encryption, Manual or IKE/ISAKMP key management, Quick/Main/Aggressive Negotiation modes, and VPN authentication support using either an external RADIUS server or the internal 500-user database.
Configurable User Interface
The DFL-210 features an intuitive user interface that can easily be configured via D-Link’s Web-based interface and monitored using the Command Line Interface (CLI). These configuration options can be managed through Admin, Read/Write, or Read-only administrator rights. With these access management levels, any authorized user can easily configure or access the administrative functions of the DFL-210.
With businesses becoming increasingly network-dependent, the need to invest in a reliable security solution is crucial. The D-Link DFL-210 Network Security Firewall offers high return on investment through robust security features, flexible configuration, and maximum network protection for SOHO networks
מאפיינים כללים
Technical Specifications
Firewall Mode of Operation
Layer 3 Mode: Route Mode, NAT Mode
Layer 2 Mode: Transparent Mode
Port Address Translation (PAT)
Policy-Based NAT
Port Forwarding
Static Address Translation (SAT)
Time Scheduled Policies
VPN Security
VPN Tunnels: 100* (IPSec, PPTP, L2TP)
IPSec LAN-to-LAN / Roaming User
PPTP/L2TP Server/Client
IPSec/PPTP/L2TP Pass-through
IPSec NAT-Traversal
DHCP over IPSec
Encryption Transform: DES, 3DES, AES, Twofish, Blowfish, CAST-128
XAUTH (Extended Authentication) for IPSec Authentication
Firewall Security
Stateful Packet Inspection (SPI)
Policy-Based User Authentication
DoS/DDoS Attack Protection
RADIUS, LDAP, IAS
HTTP Traffic Filter: Keyword, URL, Exempt List
Script Filter: Java Applet, Java Scripts, VB Scripts, Cookies, ActiveX
Network Service
Static IP address
PPPoE for xDSL
PPTP/L2TP Client for xDSL
DHCP Client for WAN Interface
BigPond Cable, Telia Compliance
Internal DHCP Server
DHCP Relay
WAN Failover/Load Sharing**
IP Alias
Static Routes
Policy-Based Routing
DNS Resolving of Remote Gateway
Dynamic DNS Poster
Custom Application Layer Gateway
Support IEEE 802.1q VLAN Tag (8)
Firewall Policies per VLAN Tag
DHCP Server per VLAN Tag
Bandwidth Management
Guaranteed Bandwidth
Maximum Bandwidth
Priority-Bandwidth Utilization
Policy-Based Traffic Shaping
Time-Scheduled Traffic Shaping
Bandwidth Management in VPN Tunnel
System
SYSLog Support
Firmware Configuration Backup
E-mail Alerts
Management – HTTP/HTTPS/SSH
Simple Network Time Protocol (SNTP)
Simple Network Management Protocol (SNMP)
Configuration Consistency Checks
Intrusion Detection System
NIDS Pattern Auto Update
Attack Alarm via E-mail Notification
Device Ports
WAN: 1 10/100BASE-TX Port
LAN: 4 10/100BASE-TX Ports
DMZ/WAN2: 1 10/100BASE-TX Port
Console Port: Serial COM Port
Diagnostic LED
Power
System
LAN (Link/Activity per Port)
WAN (Link/Activity per Port)
DMZ (Link/Activity per Port)
Power Input
5VDC, 3.0A Switching External Power Supply
Power Consumption
15 Watts max.
Dimensions
Item: 9.25” x 6.38” x 1.42”
Packaging: 10.79” x 8.19” x 4.64”
Weight
Item: 1.1 lbs
Packaging: 2.66 lbs
Temperature
Operating: 32°F to 140°F
Storage: -4°F to 158°F
Humidity
5% to 95% (Non-Condensing)
Emission (EMI)
FCC Class A
CE
C-Tick
Safety
UL
TUV
LVD (EN60950)
Warranty
3 Year Limited
תקנים
הורדות
איורים
DFL-210
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
