DS-605EOL EOS
רשיון + CD עבור VPN Client (חבילת 5 רשיונות)
תאור
Works With:
Desktop VPN Firewall
DFL-800
Rackmount VPN Firewall
DFL-1600
D-Link®, provider of Firewall/VPN Security Appliances, introduces the VPN Client software to complement the NetDefend family of firewall hardware. This VPN client software provides a complete and secure way for remote clients to communicate with their company headquarters. With growing concerns over network security, Denial of Service attacks, virus damage, and privacy demands, D-Link’s NetDefend family of network security solutions offer the reliability and protection that businesses need.
IPSec Client Solution
The D-Link VPN Client Software is an easy-to-use, secure and economical IPSec client. Designed for IPSec Virtual Private Network (VPN) products, each computer running this VPN client can instantly connect to D-Link IPSec-enabled gateways, such as D-Link VPN routers and NetDefend firewalls over a wired or wireless network, the Internet or a private network.
VPNC AES Interop Certified
VPNC Basic Interop Certified
In addition, D-Link’s VPN client is VPNC (VPN Consortium) Certified to ensure compatibility with other approved manufacturers’ firewall hardware. When a connection is established between the VPN firewall and the VPN client, all data traversing the network is protected by the latest encryption algorithms to ensure maximum security.
Data Encryption & User Authentication
The D-Link VPN Client uses standards-based IPSec with advanced 3DES/AES encryption and Windows® support. This software provides the capability to work with most RADIUS authentication methods and also supports centralized database management.
Intuitive Security Solution and Management
With the D-Link VPN Client, your mobile users have a simple and straightforward solution for securely accessing the corporate network. The D-Link VPN Client software provides mobile users with secure, reliable access to sensitive resources through broadband, wireless, or dial-up connections. Roadwarriors and telecommuters can easily communicate via hotspots on the road or via their home connection using IPSec NAT-Traversal.
The D-Link VPN Client uses innovative technology for enhanced Microsoft® Windows integration in order to improve ease of use. The D-Link VPN Client provides users with a cost-effective and secure method to access their corporate resources from any location, using the Internet or IP network environment
מאפיינים כללים
Specifications
System Requirements
CPU: 550MHz or above
DRAM: 128MB
Available hard disk space: 15MB
Operating System: Windows XP/2000
Encryption
168-bit Triple Data Encryption Standard (3DES) and 56-bit Data Encryption Standard (DES)
Message-Digest Algorithm (MD5) or Secure Hash Algorithm (SHA-1)
Advanced Encryption Standard (AES) (128-bit, 192-bit and 256-bit)
Group Support
Group 1: MODP 768
Group 2: MODP 1024
Group 5: MODP 1536
Authentication Mechanism
Pre-shared keys
RADIUS
NT Domain (Windows NT)
XAUTH (Extended Authentication) support
Profile Setting on Default (Phonebook)
8 Predefined Profiles (DFL-80, DFL-200, DFL-300, DFL-700, DFL-1100, DI-804HV, DI-808HV, DI-824VUP+)
Dialer
Key Management
Full IKE (ISAKMP/Oakley)
IKE Modes
Main Mode/Aggressive Mode
Quick Mode
PFS (Perfect Forward Secrecy) Mode
IPSec Modes
Tunnel Mode
Transport Mode
Compression
IPCOMP (IP Compression)
Deflate and plug-in support for LZS
Additional Security Features
NAT Traversal (NAT-T)
IKE keep alive (Tunnel keep alive)
Event log
Block and Central Tunneling
Set MTU size
Support for Dynamic DNS (DDNS)
DPD (Dead Peer Detection)
Seamless Re-keying
Fragmentation and Reassembly
Warranty
90-Day Software Warranty
תקנים
הורדות
איורים
DS-605
מראה מקדימה
דף מידע
ראה גם
