DFL-1600EOL EOS
פיירוול IPS לאבטחת רשת ארגונית - 6 יציאות ג'יגהביט ניתנות להגדרת משתמש ( LAN / WAN / DMZ ) - עד 320Mbps
תאור
  Main Features:
* 6 user configurable (LAN / WAN / DMZ) Gigabit ports
* Firewall Throughput: 320Mbps
* VPN Throughput: 120Mbps
* Concurrent sessions: 400,000
* Policeis: 2500
* Dedicated VPN Tunnels: 1200
  Works With:
Web Smart 48-Port Gigabit Switch
DGS-1248T
The NetDefend family of Firewall/VPN Security Appliances is D-Link’s answer for hardware-based network security. The new DFL-1600 NetDefend Network Security Rackmount VPN Firewall is an easy-to-deploy VPN and firewall solution designed for enterprise and small-to-medium sized businesses that demand superior performance and security.
Advanced Hardware Features
The DFL-1600 is a powerful security solution that provides integrated Network Address Translation (NAT), SPI Firewall, advanced content filtering features, IDS protection, bandwidth management, as well as Virtual Private Network (VPN) support. The DFL-1600 includes six configurable gigabit Ethernet ports that can be used for LAN, WAN, and DMZ. All of these features conveniently fit into a 1U rack-mountable chassis that can be easily integrated into your switch/server rack.
ICSA Labs Certified - IPSec Enhanced
ICSA Labs Certified
VPNC AES Interop Certified
VPNC Basic Interop Certified
Enterprise-class Security
To provide enterprise-class network security, the DFL-1600 has several flexible firewall features to manage, monitor, and maintain a healthy and secure network. Network management features include: Remote Management, Bandwidth Control Policies, URL/Keyword Blocking, Access Policies, and SNMP. For network monitoring, the DFL-1600 supports e-mail alerts, system log, consistency checks, and real-time statistics. For at a glance monitoring, the 20x2 line LCM display provides hardware status info as well as alert events to enable visual verifications. These features along with a firmware backup function provide and maintain maximum network performance and security.
VPN Performance
For optimal VPN configuration, the DFL-1600 has both an integrated VPN Client and Server to support almost any required VPN policy. This high-end appliance has a hardware VPN engine to support and manage up to 1200 VPN connections. The DFL-1600 can support IPSec, PPTP, and L2TP protocols in Client/Server mode and can handle pass-through traffic as well. Advanced VPN configuration options include: DES/3DES/AES/Twofish/Blowfish/CAST-128 encryption, Manual or IKE/ISAKMP key management, Quick/Main/Aggressive Negotiation modes, and VPN authentication support using either an external RADIUS server or the internal 500-user database.
Multiple Network Central Features
Additional network control features supported by the DFL-1600 include 802.1q VLAN tagging and extensive High Availability (HA) features. VLAN tagging supports integration of the DFL-1600 into your rack system with L2/L3 managed switches to segment your network and prioritize traffic. HA options include WAN Fail-Over, Active/Passive Modes, Device Failure Detection, Link Failure Detection, and Session Synchronization. Additionally, support for Active Clustering or Load Balancing optimizes network uptime and performance.
Configurable User Interface
The DFL-1600 can be configured via D-Link’s Web-based interface and monitored using the Command Line Interface (CLI). These configuration options can be managed through Admin, Read/Write, or Read-Only administrator rights. With these access management levels, any authorized user can easily configure or access the administrative functions of the DFL-1600.
With businesses becoming increasingly network-dependent, the need to invest in a reliable security solution is crucial. The D-Link DFL-1600 NetDefend Network Security Rackmount VPN Firewall offers high return on investment through robust security features, flexible configuration, and maximum network protection
מאפיינים כללים
Firewall Mode of Operation
Layer 3 Mode: Route Mode, NAT Mode
Layer 2 Mode: Transparent Mode
Port Address Translation (PAT)
Static Address Translation (SAT)
Policy-Based NAT
Port Forwarding
Server Load Balancing
Time Scheduled Policies
VPN Security
VPN Tunnels: 1200 (IPsec, PPTP, L2TP, L2TP with IPsec)
IPSec LAN-to-LAN / Roaming User
PPTP/L2TP Server/Client
IPsec Hub and Spoke
IPSec NAT-Traversal
DHCP over IPSec
Encryption Transform: DES, 3DES, AES, Twofish, Blowfish, CAST-128
XAUTH (Extended Authentication) for IPSec Authentication
Firewall Security
Stateful Packet Inspection (SPI)
Policy-Based User Authentication
DoS/DDoS Attack Protection
RADIUS, LDAP, IAS
HTTP Traffic Filter: Keyword, URL, Exempt List
Script Filter: Java Applet, Java Scripts, VB Scripts, Cookies, ActiveX
Network Service
Static IP address
PPPoE for xDSL
PPTP/L2TP Client for xDSL
DHCP Client for WAN Interface
BigPond Cable, Telia Compliance
Internal DHCP Server
DHCP Relay
WAN Failover/Load Sharing
IP Alias
Static Routes
OSPF Dynamic Routing
Policy-Based Routing
DNS Resolving of Remote Gateway
Dynamic DNS Poster
Custom Application Layer Gateway
Support IEEE 802.1q VLAN Tag (128)
Firewall Policies per VLAN Tag
DHCP Server per VLAN Tag
Bandwidth Management
Guaranteed Bandwidth
Maximum Bandwidth
Priority-Bandwidth Utilization
Policy-Based Traffic Shaping
Time-Scheduled Traffic Shaping
Bandwidth Management in VPN Tunnel
System
SYSLog Support
Firmware Configuration Backup
E-mail Alerts
Management – HTTP/HTTPS, SSH
Simple Network Time Protocol (SNTP)
Simple Network Management Protocol (SNMP)
Configuration Consistency Checks
Intrusion Detection System
NIDS Pattern Auto Update
Attack Alarm via E-mail Notification
High Availability
Active-Passive HA mode
Network Notification on Failover
Configuration Synchronization
Firewall/VPN Session Synchronization
Average Failover Time: < 800ms
Physical & Environmental
Diagnostic LEDs
Power
System
Gigabit Ethernet (Link/Activity per Port)
Device Ports
Gigabit Ethernet: 6 10/100/1000BASE-T Ports
Console Port: Serial COM port
LCM Module
20 x 2 Line Liquid Crystal Module
Display HW Status and Events
Power Input
AC Input 100~240VAC 50~60Hz
Power Consumption
200 Watts Maximum
Dimensions
17.3in x 10.0in x 1.73in
19in 1U Rack Mountable
Weight
8.8 lbs (Device Only)
Temperature
Operating: 32°F to 140°F (0° to 60°C)
Storage: -4°F to 158°F (-20° to 70°C)
Humidity
5% to 95% (Non-Condensing)
Emission (EMI)
FCC Class A
CE
C-Tick
Safety
UL
LVD (EN60950)
Warranty
3 Year Limited
תקנים
הורדות
איורים
DFL-1600
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
