DFL-200EOL EOS
Firewall לאבטחת רשת up to 80 VPN Tunnels
היכן לקנות
תאור
Product Description
With the growing concerns over network security Denial of Service attacks virus threats and increasing privacy demands D-Link s NetDefend family of firewalls provides the assurance of a dedicated network security solution in a single device.The DFL-200 is a hardware-based VPN Firewall designed to meet the security and remote access needs of small to medium businesses that demand high performance at competitive prices. This reliable network security solution provides remote offices with an integrated Network Address Translation (NAT) and Stateful Packet Inspection (SPI) Firewall Denial of Service (DoS) protection as well as Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options to enhance overall network security protection. All these features come packed into a single device to provide network administrators a business-class level security solution for smaller-scale offices.Within a desktop size industrial chassis the DFL-200 VPN Firewall includes one RS-232 console port one WAN port four trusted LAN ports that allow direct connection to up to four computers or switches and one DMZ port to segment publicly accessed resources such as e-mail or FTP servers. Users on the network can connect to the Internet via the DFL-200s WAN connection which supports Dynamic IP Static IP PPPoE client or PPTP client.The DFL-200 VPN Firewall has several flexible features to manage monitor and maintain a healthy and secure network. Some network management features include: Remote management URL/Keyword Blocking Access Policies and SNMP. For network security monitoring the DFL-200 supports e-mail alerts system log consistency checks and real-time statistics. These features along with a firmware backup function provide and maintain maximum network performance and security.For advanced VPN setup the DFL-200 has a built-in hardware accelerated VPN server which supports up to 80 VPN connections.
מאפיינים כללים
Firewall Mode of Operation
Layer 3 Mode: Route Mode, NAT Mode
Layer 2 Mode: Transparent Mode
Port Address Translation (PAT)
Policy-Based NAT
Port Forwarding
Static Address Translation (SAT)
Time Scheduled Policies
VPN Security
VPN Tunnels: 100* (IPSec, PPTP, L2TP)
IPSec LAN-to-LAN / Roaming User
PPTP/L2TP Server/Client
IPSec/PPTP/L2TP Pass-through
IPSec NAT-Traversal
DHCP over IPSec
Encryption Transform: DES, 3DES, AES, Twofish, Blowfish, CAST-128
XAUTH (Extended Authentication) for IPSec Authentication
Firewall Security
Policy-Based User Authentication
DoS/DDoS Attack Protection
RADIUS, LDAP, IAS
HTTP Traffic Filter: Keyword, URL, Exempt List
Script Filter: Java Applet, Java Scripts, VB Scripts, Cookies, ActiveX
Network Service
Static IP address
PPPoE for xDSL
PPTP/L2TP Client for xDSL
DHCP Client for WAN Interface
BigPond Cable, Telia Compliance
Internal DHCP Server
DHCP Relay
WAN Failover/Load Sharing**
IP Alias
Static Routes
Policy-Based Routing
DNS Resolving of Remote Gateway
Dynamic DNS Poster
Custom Application Layer Gateway
Support IEEE 802.1q VLAN Tag (8)
Firewall Policies per VLAN Tag
DHCP Server per VLAN Tag
Bandwidth Management
Guaranteed Bandwidth
Maximum Bandwidth
Priority-Bandwidth Utilization
Policy-Based Traffic Shaping
Time-Scheduled Traffic Shaping
Bandwidth Management in VPN Tunnel
System
SYSLog Support
Firmware Configuration Backup
E-mail Alerts
Management – HTTP/HTTPS/SSH
Simple Network Time Protocol (SNTP)
Simple Network Management Protocol (SNMP)
Configuration Consistency Checks
Intrusion Detection System
NIDS Pattern Auto Update
Attack Alarm via E-mail Notification
Device Ports
WAN: 1 10/100BASE-TX Port
LAN: 4 10/100BASE-TX Ports
DMZ/WAN2: 1 10/100BASE-TX Port
Console Port: Serial COM Port
Diagnostic LED
Power
System
LAN (Link/Activity per Port)
WAN (Link/Activity per Port)
DMZ (Link/Activity per Port)
Power Input
5VDC, 3.0A Switching External Power Supply
Power Consumption
15 Watts max.
Dimensions
Item: 9.25” x 6.38” x 1.42”
Packaging: 10.79” x 8.19” x 4.64”
Weight
Item: 1.1 lbs
Packaging: 2.66 lbs
Temperature
Operating: 32°F to 140°F
Storage: -4°F to 158°F
Humidity
5% to 95% (Non-Condensing)
Emission (EMI)
FCC Class A
CE
C-Tick
Safety
UL
TUV
LVD (EN60950)
Warranty
1 Year Limited***
נתונים פיזיים
תקנים
הורדות
איורים
DFL-200
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
