DIR-615/AEOL EOS
Wireless N300 Router
תאור
Wireless Interface
Using the DIR-615 device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
In addition, the device is equipped with a button for switching the Wi-Fi network off/on. If needed, for example, when you leave home, you can easily switch the router’s WLAN by pressing the button, and devices connected to the LAN ports of the router will stay online.
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Security
The wireless router DIR-615 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy configuration and update
You can configure the settings of the wireless router DIR-615 via the user-friendly web-based interface (the interface is available in several languages).
Now you can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
מאפיינים כללים
				 Hardware
				 Interfaces
				 • 10/100BASE-TX WAN port
				• 4 10/100BASE-TX LAN ports
				 LEDs
				 • POWER
				• WPS
				• INTERNET
				• WLAN
				• 4 LAN LEDs
				 Buttons
				 • ON/OFF button to power on/power off
				• RESET button to restore factory default settings
				• WPS button to set up secure wireless connection and enable/disable wireless network
				 Antenna
				 • Two internal antennas (2.5dBi gain)
				 MIMO
				 • 2 x 2
				 Power connector
				 • Power input connector (DC)
| Software | |
				 WAN connection types
				 • PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• Static IP / Dynamic IP
				• Static IPv6 / Dynamic IPv6
				• PPPoE + Static IP / Dynamic IP
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				 Network functions
				 • DHCP server/relay
				• DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation
				• DNS relay
				• Support of DNSv6 AAAA records
				• Dynamic DNS
				• Static IP routing
				• Static IPv6 routing
				• IGMP Proxy
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• Flow control
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				 Firewall functions
				• IP filter
				• IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in Yandex.DNS web content filtering service
				 VPN
				 • IPSec/PPTP/L2TP/PPPoE pass-through
				 Management
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Multilingual web-based interface for configuration and management
				• Support of remote logging
				• Ping function
				• Traceroute utility
				• TR-069 client
| Wireless Module Parameters | |
				 Standards
				 • IEEE 802.11b/g/n
				 Frequency range
				 • 2400 ~ 2483.5MHz
				 Wireless connection security
				 • WEP
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Support of client mode
				• WMM (Wi-Fi QoS)
				• Managing connected stations
				• Advanced settings
				 Wireless connection rate
				 • IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n: from 6.5 to 300Mbps (from MCS0 to MCS15)
				 Transmitter output power
				 • 802.11b (typical at room temperature 25 °C)
				17dBm (+/-1.5dB) at 1, 2, 5.5, 11Mbps
				• 802.11g (typical at room temperature 25 °C)
				17dBm (+/-1.5dB) at 6, 9, 12Mbps
				16dBm (+/-1.5dB) at 18, 24Mbps
				15dBm (+/-1.5dB) at 36, 48, 54Mbps
				• 802.11n (typical at room temperature 25 °C)
				HT20
				16.5dBm (+/-1.5dB) at MCS0/8
				16.5dBm (+/-1.5dB) at MCS1/9
				16.5dBm (+/-1.5dB) at MCS2/10
				16dBm (+/-1.5dB) at MCS3/11
				16dBm (+/-1.5dB) at MCS4/12
				15.5dBm (+/-1.5dB) at MCS5/13
				15dBm (+/-1.5dB) at MCS6/14
				14dBm (+/-1.5dB) at MCS7/15
				HT40
				 Receiver sensitivity
				 • 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
				-82dBm at 1Mbps
				-80dBm at 2Mbps
				-78dBm at 5.5Mbps
				-76dBm at 11Mbps
				• 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
				-85dBm at 6Mbps
				-84dBm at 9Mbps
				-82dBm at 12Mbps
				-80dBm at 18Mbps
				-77dBm at 24Mbps
				-73dBm at 36Mbps
				-69dBm at 48Mbps
				-68dBm at 54Mbps
				• 802.11n (typical at PER = 10% (1000-byte PDUs))
				HT20
				-82dBm at MCS0/8
				-79dBm at MCS1/9
				-77dBm at MCS2/10
				-74dBm at MCS3/11
				-70dBm at MCS4/12
				-66dBm at MCS5/13
				-65dBm at MCS6/14
				-64dBm at MCS7/15
				HT40
				-79dBm at MCS0/8
				-76dBm at MCS1/9
				-74dBm at MCS2/10
				-71dBm at MCS3/11
				-67dBm at MCS4/12
				-63dBm at MCS5/13
				-62dBm at MCS6/14
				-61dBm at MCS7/15
				 Modulation schemes
				• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
				 Physical Parameters
				 Dimensions
				 • 160 x 120 x 59 mm (6.3 x 4.7 x 2.3 in)
				 Weight
				 • 200 g (0.44 lb)
				 Operating Environment
				 Power
				 • Output: 12V DC, 0.5A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 65 °C
				 Humidity
				 • Operating: from 10% to 90% (non-condensing)
				• Storage: from 5% to 95% (non-condensing)
				 Delivery Package
				 • Router DIR-615
				• Power adapter DC 12V/0.5A
				• Ethernet cable (CAT 5E)
תקנים
הורדות
DIR-615/A/N1  Wireless N300 Router
