DIR-615/A/M1AEOL EOS
Wireless N300 Router
תאור
4-port Switch
The built-in 4-port switch enables you to connect Ethernet-enabled computers, game consoles, and other devices to your network.
Wireless Interface
Using the DIR-615 device, you are able to quickly create a wireless network at home or in your office, which lets your relatives or employees connect to your wireless network virtually anywhere (within the operational range of your wireless network). The router can operate as a base station for connecting wireless devices of the standards 802.11b, 802.11g, and 802.11n (at the rate up to 300Mbps).
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Security
The wireless router DIR-615 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
Easy Configuration and Update
You can configure the settings of the multifunction wireless router DIR-615 via the user-friendly web-based interface (the interface is available in several languages).
Now you can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
מאפיינים כללים
Hardware
Interfaces
• Wireless interface: 802.11b/g/n (up to 300Mbps), 2.4GHz
• LAN interface: 10/100 Fast Ethernet (4 ports)
• WAN interface: 1 10/100BASE-TX Ethernet port for cable or DSL modem or private Ethernet line
Antenna
• Two external non-detachable antennas
- Antenna gain: 2dBi
MIMO
• 2x2
Frequency Range
• 2400 ~ 2483.5MHz
Data Rate
• 802.11b
- 11, 5.5, 2, and 1Mbps
• 802.11g
- 54, 48, 36, 24, 18, 12, 9, and 6Mbps
• 802.11n
MCS
GI3=800ns
GI=400ns
20MHz (Mbps)
40MHz (Mbps)
20MHz (Mbps)
40MHz (Mbps)
0
6.5
13.5
7.2
15
1
13
27
14.4
30
2
19.5
40.5
21.7
45
3
26
54
28.9
60
4
39
81
43.3
90
5
52
108
57.8
120
6
58.5
121.5
65
135
7
65
135
72.2
150
8
13
27
14.4
30
9
26
54
28.9
60
10
39
81
43.3
90
11
52
108
57.8
120
12
78
162
86.7
180
13
104
216
115.6
240
14
117
243
130
270
15
130
270
144.4
300
Modulation Schemes
• 802.11b: DQPSK, DBPSK, CCK
• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
Transmitter Output Power
• 802.11b (typical at room temperature 25 °C)
- 16dBm
• 802.11g (typical at room temperature 25 °C)
- 14dBm (+/-2dBm)
• 802.11n (typical at room temperature 25 °C)
- 12dBm (+/-2dBm)
Receiver Sensitivity
• 802.11b (typical at PER = 8% (1000-byte PDUs))
-76dBm at 1, 2, 5.5, 11Mbps
• 802.11g (typical at PER = 10% (1000-byte PDUs))
-82dBm at 6Mbps
-81dBm at 9Mbps
-79dBm at 12Mbps
-77dBm at 18Mbps
-74dBm at 24Mbps
-70dBm at 36Mbps
-66dBm at 48Mbps
-65dBm at 54Mbps
• 802.11n (typical at PER = 10% (1000-byte PDUs))
HT20
HT40
-82dBm at MCS0/8
-82dBm at MCS0/8
-79dBm at MCS1/9
-79dBm at MCS1/9
-77dBm at MCS2/10
-77dBm at MCS2/10
-74dBm at MCS3/11
-74dBm at MCS3/11
-70dBm at MCS4/12
-70dBm at MCS4/12
-66dBm at MCS5/13
-66dBm at MCS5/13
-65dBm at MCS6/14
-65dBm at MCS6/14
-64dBm at MCS7/15
-64dBm at MCS7/15
Software
Network Functions
• WAN connection types
- PPPoE
- Static IP
- Dynamic IP
- PPTP/L2TP + Static IP
- PPTP/L2TP + Dynamic IP
• DHCP server/relay
• VPN pass-through (PPTP/L2TP)
• Dynamic DNS
• Static IP routing
• Remote management
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• Support of VLAN
• Flow control
• TR-069 client
• WAN ping respond
• Support of SIP
• Support of RTSP
Wireless Connection
• Supported security settings
- WEP
- WPA/WPA2 Personal
- WPA/WPA2 Enterprise
• MAC filter
• Managing connected stations
• PIN and PBC methods of WPS
• WMM (Wi-Fi QoS)
• Advanced settings
• Support of client mode
Firewall Functions
• IP filters
• URL filter
• MAC filter
• DMZ
• Prevention of ARP and DDoS attacks
• Virtual servers
Configuration and Management
• Multilingual web-based interface for configuration and management
• Access via TELNET
• Support of remote logging
• Ping function
• Traceroute utility
Physical and Environmental
LEDs
• Power
• Internet
• WLAN
• 4 LAN LEDs
• WPS
Power
• External power adapter DC 5V/1A
Buttons
• Reset to Factory Defaults button
• WPS button
Wall Mounting
• Not possible
Operating Temperature
• From 0 to 40 0C (from 32 to 104 0F)
Storage Temperature
• From -20 to 65 0С (from -4 to 149 0F)
Operating Humidity
• From 10% to 90% non-condensing
Storage Humidity
• From 5% to 95% non-condensing
תקנים
הורדות
DIR-615/A/M1A Wireless N300 Router
