חיפוש מהיר
תכונות המוצר:
נתב אלחוטי נייד דואל-בנד בתקן AC-750 עם אפשרות טעינה ותמיכה ב - mydlink
מאפיינים כללים:
Device interfaces
• 802.11 a / b / g / n / ac (draft) Wireless LAN, up to 750 Mbit/s2
• WAN port 10/100 Ethernet
• WPS button
• Power Switch
• Reset Button
• USB 2.0 Type A (1 A) for compatible 3G/4G modems, USB-drive, or to charge other devices
• USB 2.0 Type A (0,5 A) for USB-stick or DCS-300
• Power (MicroUSB)
Indicators
• Power / Status
• The battery
Standards
• IEEE 802.11ac (draft)
• IEEE 802.11n
• IEEE 802.11b
• IEEE 802.11g
• IEEE 802.11a
• IEEE 802.3
• IEEE 802.3x
• IEEE 802.3u
• USB 2.0
Modes of Internet connection
• Broadband Router (Broadband Router)
• Mobile Router (Mobile Router)
• Wi-Fi Hotspot
Power modes
• On / Off / Charger (On / Off / Charge) 8
Frequency band
• IEEE 802.11a: 5150 MHz ~ 5850 MHz
• IEEE 802.11b: 2400 ~ 2497 MHz ISM band
• IEEE 802.11g: 2400 ~ 2483.5 MHz ISM band
• IEEE 802.11n (2,4 GHz): 2400 ~ 2483.5 MHz ISM band
• IEEE 802.11n (5 GHz): 5180 MHz ~ 5320 MHz, 5745 MHz ~ 5825 Hz
• IEEE 802.11ac (draft) (5 GHz): 5180 MHz ~ 5320 MHz, 5745 MHz ~ 5825 MHz
Speed ​​wireless
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11n (5 GHz): 6.5 ~ 150 Mbit / s
Transmitter output power
• IEEE 802.11a:
   17 dBm (+ /-1dB) at 6-18 Mbit / s
   16 dBm m (+ /-1dB) for 24-36 Mbit / s
   DBm 14 dBm (+ /-1dB) for 48-54 Mbit / s
• IEEE 802.11b: 17dBm at 1,2,5,5,11 Mbit / s
• IEEE 802.11g:
   18 dBm at 6-18 Mbit / s
   24-36 dBm at 16 Mbit / s
   48-54 dBm at 14 Mbit / s
  17 dBm (+ /-1dB) at MCS3 ~ MCS0
  16 dBm (+ /-1dB) at MCS5 ~ MCS4
  14 dBm (+ /-1dB) at MCS7 ~ MCS6
  18 dBm at MCS 3 ~ 0
  16 dBm at MCS 5 ~ 4
  14 dBm at MCS 7 ~ 6
  21 dBm at MCS 11 ~ 8
  19 dBm at MCS 13 ~ 12
  17 dBm at MCS 15 ~ 14
  17 dBm at MCS3 ~ MCS0
  16 dBm at MCS5 ~ MCS4
  14 dBm at MCS7 ~ MCS6
  13 dBm at MCS9 ~ MCS
Antennas
• Internal antennas
Functionality
• Appendix mydlink SharePort
• For iPhone ®, iPad ®, iPod touch ® and Android ™
• The remote access: access files over a network Internet7
• The local access: Access your files from any device connected to the DIR-510L
• SharePort Web Access (access via Web-browser)
• Access your files from any device connected to the DIR-510L
• Application support SharePort Mobile devices based on Windows ® 8/RT
Security
• Wi-Fi Protected Access (WPA/WPA2)
• 64/128-bit WEP-shifrovanie5
• WPS 2.0 (PBC)
Advanced Features
• Support for Guest Zone
• IPv6
• Wi-Fi WMM Quality of Service (QoS)
• Supports UPnP
• Media Server DLNA4
Advanced Firewall Features
• MAC-address filtering
Device control
• Management via Web-interface with PC and mobile phone
נתונים פיזיים
Measurements
• 140 x 59 x 16 mm
Weight
• 154 grams
Power
• Built-in lithium-ion battery capacity of 4000 mA / h
• Input:  max 5 V DC / 1,8 A (standard adapter);
• Output:  5 V / 1 A   (USB-port Type A)
                 5 V / 0,5 A (USB-port Type A)
Temperature
• Operating: 0 to 40 ° C
• Storage: -10 to 45 ° C
Humidity
• Operating: 10 to 75% non-condensing
• Operating:   5 to 75% non-condensing
Certificates
• FCC
• CE
• IC
• C-Tick
• NCC
• cUL
• LVD
• BSMI
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
