חיפוש מהיר
תכונות המוצר:
נתב אלחוטי הכולל גם 4 יציאות רשת קוויות, פועל בתקן 802.11n במהירות עד 150Mbps
דגם לא מיוצר יותר
מאפיינים כללים:
WAN interface
• 1 10/100BASE-TX Ethernet port for cable or DSL-modem or a dedicated Ethernet-line
LAN interface
• 4-port 10/100BASE-TX Ethernet
WLAN interface
• IEEE 802.11n (up to 150 Mbit / s)
• IEEE 802.11b / g
Network Features
• Types of WAN-connection
• PPPoE
• Static IP
• Dynamic IP
• PPTP/L2TP + Static IP
• PPTP/L2TP + Dynamic IP
• DHCP-Server and DHCP-Client
• DNS relay
• Skip VPN-tunnel (PPTP/L2TP)
• Dynamic DNS
• Static IP-routing
• Remote Access
• Network statistics for each interface
• IGMP Proxy
• RIP
• UPnP
• Support for VLAN
Wireless connection
• Segmentation of the wireless network (up to 4 SSID)
• Supported Standards Safety
  ◦ WEP
  ◦ WPA/WPA2 Personal
  ◦ WPA/WPA2 Enterprise
  ◦ MAC Filter
• Control of the connected devices
• Methods and PIN WPS PBC function
• The WMM (Wi-Fi QoS)
• Advanced
• Supports the "client"
Firewall Security
• Monitor the status of connections (SPI)
• IP-filters
• URL-Filter
• MAC-filter
• DMZ-zone
• The protection and ARP-DDoS-attacks
• Virtual Servers
Configuring and Managing
• Web-based interface for configuration and management of multiple languages
• Access to TELNET
• Upgrade the firmware of the router through the web-interface
• Save and load configuration
• Support for remote logging
• Automatic synchronization of the system time with the NTP-server
Indicators
• Power
• Internet
• Wireless
• 4 LEDs LAN
נתונים פיזיים
Power
• Power supply: External Power Adapter DC 5V/1A
Reset button to restore factory default settings
Operating temperature
0 to 40 C
Storage temperature
-20 To 65 C
Operating humidity
From 10% to 90% non-condensing
Storage humidity
From 5% to 95% non-condensing
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
