DIR-412EOL EOS
נתב אלחוטי סלולרי הפועל עד 150Mbps, תמיכה ברשתות 3G EVDO/CDMA/HSUDPA/HSDPA/UMTS
היכן לקנות
תאור
Maximum Portability
The D-Link Mobile Wireless Router allows users to access worldwide mobile broadband. Simply insert a compatible 3.5G USBadapter and share your 3.5G Internet connection through a secure, high-speed wireless network. Enjoy increased speed and range over traditional 802.11g/b standards2 thanks to the latest Wireless N150 technology. A10/100 Ethernet WANport allows you to attach a DSL/Cable modem as the primary or backup link, while auto-failover ensures an uninterrupted connection by automatically connecting to your 3.5G network whenever the WANlink is lost.
Advanced Network Security
The DIR-412 ensures a secure Wi-Fi network through the use of WPA/WPA2 wireless encryption. Simply press the WPSbutton to quickly establish a secure connection to new devices. The DIR-412 also utilizes dual-active firewalls (SPIand NAT) to prevent potential attacks and intrusions from across the Internet.
Simple to Install and Use
The Mobile Wireless Router can be installed quickly and easily almost anywhere. This router is great for situations where an impromptu wireless network must be set up, or wherever conventional network access is unavailable. The DIR-412 can even be installed on buses, trains, or boats, allowing passengers to check e-mail or chat online while commuting.
Modem Compatibility List
Please check the compability with local D-Link Office.
מאפיינים כללים
תאימות עם רשתות
  • 1x EV-DO/CDMA
  • HSUPA/HSDPA/UMTS
אבטחה אלחוטית
  • WEP
  • WPA\WPA2
  • WPS
Firewall
  • NAT
  • SPI
  • MAC-Filtering
  • Web-Filtering
VPN
  • L2TP/PPTP/IPSEC VPN Pass-through
  • PPTP/L2TP Connection
כניסות
  • 1 - Ethernet
  • 1 - USB 2.0
מהירות העברת נתונים
  • 802.11b:11,5.5,2,1
  • 802.11g:54,48,36,24,18,12,9,6
  • 802.11n: 150
משדר
  • IEEE 802.11b:
      17 dBm (+/-2dB) 11, 5.5, 2 , 1 Mbps
  • IEEE 802.11g:
      16dBm 6~12 Mbps
      16dBm 18 Mbps
      15dBm 24 Mbps
      15dBm 36 Mbps
      14dBm 48 Mbps
      14dBm 54 Mbps
  • IEEE 802.11n:
      15dBm MCS0~2
      15dBm MCS3
      14dBm MCS4
      14dBm MCS5
      13dBm MCS6
      13dBm MCS7
    רגישות מקלט
  • IEEE 802.11b
    –81dBm 11 Mbps
    –82dBm 5.5 Mbps
    –84dBm 2 Mbps
    –86dBm 1 Mbps
  • IEEE 802.11g:
    –84dBm 6 Mbps
    –83dBm 9 Mbps
    –82dBm 12 Mbps
    –79dBm 18 Mbps
    –77dBm 24 Mbps
    –74dBm 36 Mbps
    –70dBm 48 Mbps
    –68dBm 54 Mbps
  • IEEE 802.11n:
    HT20
    –86dBm MCS0
    –84dBm MCS1
    –80dBm MCS2
    –76dBm MCS3
    –74dBm MCS4
    –72dBm MCS5
    –70dBm MCS6
    –68dBm MCS7
    HT40
    –82dBm MCS0
    –80dBm MCS1
    –77dBm MCS2
    –73dBm MCS3
    –71dBm MCS4
    –67dBm MCS5
    –65dBm MCS6
    –64dBm MCS7
מנורות חיווי
  • Power
  • Internet
  • Wireless
  • Ethernet
  • WPS
נתונים פיזיים
מידות
  • 122X97X27 מ"מ
משקל
  • 120 גרם
ספק כח
  • 5V - 2.5A
תקנים
הורדות
איורים
DIR-412
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
