DIR-412EOL EOS
תאור
Maximum Portability
The D-Link Mobile Wireless Router allows users to access worldwide
mobile broadband. Simply insert a compatible 3.5G USBadapter and share
your 3.5G Internet connection through a secure, high-speed wireless
network. Enjoy increased speed and range over traditional 802.11g/b
standards2 thanks to the latest Wireless N150 technology. A10/100
Ethernet WANport allows you to attach a DSL/Cable modem as the primary
or backup link, while auto-failover ensures an uninterrupted connection
by automatically connecting to your 3.5G network whenever the WANlink is
 lost.
Advanced Network Security
The DIR-412 ensures a secure Wi-Fi network through the use of
WPA/WPA2 wireless encryption. Simply press the WPSbutton to quickly
establish a secure connection to new devices. The DIR-412 also utilizes
dual-active firewalls (SPIand NAT) to prevent potential attacks and
intrusions from across the Internet.
Simple to Install and Use
The Mobile Wireless Router can be installed quickly and easily
almost anywhere. This router is great for situations where an impromptu
wireless network must be set up, or wherever conventional network access
 is unavailable. The DIR-412 can even be installed on buses, trains, or
boats, allowing passengers to check e-mail or chat online while
commuting.
Modem Compatibility List
Please check the compability with local D-Link Office.
מאפיינים כללים
תאימות עם רשתות
- 1x EV-DO/CDMA
 - HSUPA/HSDPA/UMTS
אבטחה אלחוטית
- WEP
 - WPA\WPA2
 - WPS
Firewall
- NAT
 - SPI
 - MAC-Filtering
 - Web-Filtering
VPN
- L2TP/PPTP/IPSEC VPN Pass-through
 - PPTP/L2TP Connection
כניסות
- 1 - Ethernet
 - 1 - USB 2.0
מהירות העברת נתונים
- 802.11b:11,5.5,2,1
 - 802.11g:54,48,36,24,18,12,9,6
 - 802.11n: 150
משדר
- IEEE 802.11b:
17 dBm (+/-2dB) 11, 5.5, 2 , 1 Mbps - IEEE 802.11g:
16dBm 6~12 Mbps
16dBm 18 Mbps
15dBm 24 Mbps
15dBm 36 Mbps
14dBm 48 Mbps
14dBm 54 Mbps - IEEE 802.11n:
15dBm MCS0~2
15dBm MCS3
14dBm MCS4
14dBm MCS5
13dBm MCS6
13dBm MCS7
רגישות מקלט - IEEE 802.11b
–81dBm 11 Mbps
–82dBm 5.5 Mbps
–84dBm 2 Mbps
–86dBm 1 Mbps - IEEE 802.11g:
–84dBm 6 Mbps
–83dBm 9 Mbps
–82dBm 12 Mbps
–79dBm 18 Mbps
–77dBm 24 Mbps
–74dBm 36 Mbps
–70dBm 48 Mbps
–68dBm 54 Mbps - IEEE 802.11n:
HT20
–86dBm MCS0
–84dBm MCS1
–80dBm MCS2
–76dBm MCS3
–74dBm MCS4
–72dBm MCS5
–70dBm MCS6
–68dBm MCS7
HT40
–82dBm MCS0
–80dBm MCS1
–77dBm MCS2
–73dBm MCS3
–71dBm MCS4
–67dBm MCS5
–65dBm MCS6
–64dBm MCS7
מנורות חיווי
- Power
 - Internet
 - Wireless
 - Ethernet
 - WPS
