DIR-100/FEOL EOS
תאור
High permormance
The D-Link DIR-100 broadband router is designed to let a group of users
share a broadband Internet connection through a DSL or cable modem. Easy
to setup and operate, this router is ideal for novice home and small
offce users creating their frst networks.
Quality of service (QoS)
The DIR-100 provides prioritized transmission and reception of VoIP and
on-line packets to/from the Internet to enable a group of users to
experience the beneft of smooth network connection of inbound and
outbound data without concern of traffc congestion. This QoS support
allows users to enjoy high broadband transmission for applications such
as Internet phones, multimedia and games over the Internet.
Total network security
The DIR-100 router provides frewall protection for network computers
again Internet DoS and virus attacks. It flters packets to screen access
control based on port and source/destination MAC/IP addresses. With
Port Forwarding, the router can be set up to allow separate FTP and
multiple games to share the same Internet-visible IP address while still
protecting servers and workstations from hackers. Users can set up a
home or offce web site by confguring any of the built-in LAN ports to
function as a DMZ port. Parental Control allows parents and network
administrators to flter out undesired URL web sites, block domains and
control the time of day of the use of Internet through scheduling.
מאפיינים כללים
WAN
- 1 פורט SFP לחיבורים אופטיים 10/100Mbps
- תמיכה ב Always-on - bridged ו PPPoE לחיבורים PPP
LAN
- 4 פורטים 10/100BASE-TX Ethernet
- תמיכה ב - MDI/MDIX
VPN
- PPTP pass-through
- IPSec pass-through
- L2TP pass-through
QoS ועוד
- עדיפות תעבורת VOIP
- הגדרה וניהול עם IGMP
- NAT
- DHCP
- DDNS
- UPnP
- NTP
- ניהול מרחוק דרך Telnet
